Old 04-04-2017, 12:49 PM   #43
Hyper1SS
Hyper1SS's Avatar
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP
Originally Posted by burnningice View Post
Here is my final setuo
So I see you got you enclosure. Overall what do you think? Is it what you expected or better? I got mine adjusted the way I want now and love the overall sound with the added bass!!
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates.
Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges
Order ID: TDHQMS
1100 on 01/07/2016 at Penske Chevrolet
6000 on 02/23/2016 Delivered to customer
Hyper1SS is offline   Reply With Quote
Old 04-04-2017, 01:08 PM   #44
burnningice
burnningice's Avatar
Drives: 2016 SS Mosaic Black
So much happier with the sub. Still wish it was an aftermarket radio because of control and signal but it works. I found that SXM has a horrible sound
burnningice is offline   Reply With Quote
Old 04-04-2017, 03:33 PM   #45
Hyper1SS
Hyper1SS's Avatar
Right not much control from this head unit. Are you running a bass knob up front? I have not decided if I want one yet or not. Once I get to drive the Camaro more when the weather breaks I will figure it out then. How do you like the New L7?
Order ID: TDHQMS
Old 04-04-2017, 04:57 PM   #46
burnningice
No bass knob. I may add later. Love the L7
Old 04-04-2017, 05:04 PM   #47
Hyper1SS
Hyper1SS's Avatar
The L7 is what I was wanting to go with and still might. How is the enclosure working out? What's it tuned at?
Order ID: TDHQMS
Old 04-09-2017, 02:37 PM   #48
Marobeast69
Marobeast69's Avatar
Drives: 2016 Chevy camaro lt
What wires can I use my 2016 Chevy Camaro LT did not come with a factory amp I would like to put subwoofers
Marobeast69 is offline   Reply With Quote
Old 04-09-2017, 02:41 PM   #49
burnningice
Are you looking for a turn-on wire?
Old 04-09-2017, 06:23 PM   #50
Marobeast69
Yes and to get my RCA converter connected
Old 04-09-2017, 06:28 PM   #51
burnningice
The wiring information is on page 3. The 3rd picture that I posted shows your radio wiring diagram. I'm not sure if your car has wires running to the trunk for anow amp option. Worst case you can get the wires from the radio. You will want to use the front speakers for signal because they are full range. You can probably get a switched ignition wire at the fuse box in the trunk. But the only retained accessory power that I know of is the cigarette lighter in the center console.
Old 04-09-2017, 06:33 PM   #52
Marobeast69
Yes it does I only have a small black box with wires on left rear side but no amp and is that diagram the same for all models LT RS SS
Old 04-09-2017, 06:38 PM   #53
Marobeast69
Just wana know if I can tap into that black box and what wires to tap in my RCA converter
Old 04-09-2017, 06:39 PM   #54
burnningice
The ss have an amp even if it's not bose. You can meter the wires to test. You can also post a pic.
Old 08-15-2017, 05:45 PM   #55
sharkeater
sharkeater's Avatar
Drives: 2016 Chevy Camaro 1SS
Which 4 wires did you tap into to grab the pre amp audio signal?
sharkeater is offline   Reply With Quote
Old 08-25-2017, 09:57 PM   #56
Polishdevil
Drives: 2017 SS M6
So the 1SS only has 4 speakers?
Polishdevil is offline   Reply With Quote
