#43 | |
http://www.camaro6.com/forums/forumdisplay.php?f=256
#44 | |
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
Let me know if I understand this right. Density Altitude (DA) is a measure of the air density at a given altitude, adjusted for barometric pressure and relative humidity. For our purposes, this basically tells us how much oxygen we can pack into each cubic foot of air going into the intake for combustion. I was a helicopter crew chief and mechanic for half my USMC career so I have some insight on this relationship. Aircraft have 2 altimeters, a barometric altimeter concerned with engine and rotor performance and a radar altimeter that keeps you from violating restricted airspace or clipping power lines and such. Jet and turbojet engines also benefit from high density air, so long as it's clean and cool. Turbojet engines are all about compressing air for combustion, similar to superchargers and turbochargers. I understand that, all else being equal, a higher barometric pressure will cause more atmospheric oxygen to be concentrated in a cubic foot of air. What I'm not sure about is how the humidity / dew point affects this. Is it assumed that moisture will displace oxygen within a given volume of air? --Cal |
#45 | |
Cal
I know I short shifted one or two times but I'm pretty sure I kept it above 6400 most of the time. The sound in the spectator vids is affected by the doppler effect, raising the pitch on the low end (approaching the camera) and lowering it on the high end (going away from camera). So you think 6200 RPM is at the top of the power band for this LT4 motor? It seems to still be pulling hard after that. If memory serves, it begins to drop off around 6400 or better, depending on what gear I'm in. I did hot lap most of the day to get in as many practice runs as possible. I shut the motor off for about 15 min or so each time they halted the street car line for the dragsters and motorcycles. That gave me 3 or 4 runs each time before shutting down. I could have gotten 1 or 2 more per cycle if I switched lanes on the turnaround since for some reason the left lane always had fewer cars lined up. I was staying in the right lane for most of my runs 'cause that's where my GoPro was mounted. Thanks for the feedback. --Cal |
#46 | |
Cal
Only thing I can do with the suspension is tires but I'm not sure I want to spend the $$ on DRs if I don't plan to make drag racing my primary activity. My plans are mainly focused on road courses. I'm not ready to throw away the warranty yet by getting an engine tune but I think I can improve my 60' times with a little work on the manual launch and my MPH and ETs with work on my shift points. Thanks for the insights. --Cal |
#47 |
I agree with 93oh on the launch. If you watch magazine drivers, when they test a car like this but it has street tires, they launch at low RPM, like 1000-1500, and add gas as rapidly as they can while still maintaining traction. Dumping it at 4000 or using launch control doesn't achieve as good of results. I remember one tester doing the 5th gen ZL1 and he used Launch control and did a 4.1 0-60, and then did it by himself and went like 3.8, same car, same tires, in the same 10 minutes.
#48 | |
Cal
Thanks. --Cal |
#49 |
Cal
#50 | |||
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Full exhaust, lower pulley, E35 -10.36 at 133 mph 690 DA straight from the street with a slight spin at launch. TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
#51 | |
Cal
I've always enjoyed writing and I'm kind of picky when choosing my words. I want to be sure that my thoughts come across accurately. I've learned to be very specific with my work in computer software/hardware analysis. I try to be as unambiguous as possible when reviewing something or asking/answering questions. It does take a little work to put things together the way I want but I think it's worth it with the great feedback I'm getting. If I can accurately document and analyze my driving skills and equipment it should result in improvements at the track. I hope that others like me can gain from it too. You probably don't get much track time up there in Ohio this time of year, huh? Here's hoping you get some track days soon. ![]() --Cal |
#52 |
Cal
That's a sweet lookin' ride you got there Mr. "Beefcake".
You must have gotten that nickname from the girls around town huh? These cars are chick-magnets but, judging by your physique you probably don't need it for that. I'm not in the physical condition I was in my 20s and 30s but I try to stay healthy going on 62 now. Good health pays of racing on road courses. I found that out at Bondurant racing school. It was surprisingly physically and mentally draining but totally exhilarating. Seriously though, I checked out your Camaro6 album. That car is beautiful. It must be quick too, based on the specs I see. I'm glad you got some smiles out of the videos. I'll try to keep 'em coming. --Cal |
#53 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 GT350 Join Date: Jan 2011
Well it looks like all this talk about the larger rear tires and the new compound being able to hook this car up is out the window. As expected trying to harness 650-lbs of torque on street rubber is an exercise in frustration.
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot |
#54 | |
Cal
Thank you for the ID on the car in video 7. I'll update my video notes. You don't happen to know what model Nissan that is in videos 4 and 6 do you? --Cal |
#55 |
Cal
#56 | ||||||
Cal
![]() Quote:
The formula cars I drove at Bondurant school had the LED rev indicators. It was very helpful. I've been going pretty much by the sound of the motor 'til now. Quote:
Now I'm going to be more aware of what I'm putting the supercharger through. Quote:
--Cal |
