Old 04-07-2018, 03:32 PM   #43
Want1
Drives: 2017 Camaro SS 1LE
Originally Posted by JANNETTYRACING View Post
I thought i would bump this up for the new blood to see.
Awesomeness again!!
Great read!
Thank you, Ted!
Want1 is offline   Reply With Quote
Old 04-08-2018, 10:15 AM   #44
carlosgrana
Drives: 2016 camaro ss
What spark plugs and gap did you use for thise power level
carlosgrana is offline   Reply With Quote
Old 04-08-2018, 05:23 PM   #45
JANNETTYRACING
JANNETTYRACING's Avatar
NGK 1 heat range colder OEM equivilent 0.042
www.jannettyracing.com
email tedj@jannettyracing.com
Old 04-21-2018, 08:47 AM   #46
JANNETTYRACING
Originally Posted by Want1 View Post
Awesomeness again!!
Great read!
Thank you, Ted!
Thank you, Hard to believe this is over 1 year ago already, Lots of great info in this thread.
Old 04-24-2018, 12:48 AM   #47
Drsagacity
Drsagacity's Avatar
Ted, I just emailed you. What fuel components do I need so I can bump up to the 90mm pulley?
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 04-24-2018, 07:14 AM   #48
JANNETTYRACING
You will need our JRE LT-1 fuel system upgrade package, Maybe you already have 1 or more of these parts Please call or email me and I will get you set up with what you need to fill in the blanks.
Thank you for your business.
Ted.
Old 06-14-2018, 03:19 PM   #49
Drsagacity
Drsagacity's Avatar
Ted,
Wondering if we added an aux fuel system would that change the calculations here? Do you prefer the idea of running race gas on occasion compared to alky injection (personal preference)?
TBD performance
Old 06-14-2018, 04:10 PM   #50
JANNETTYRACING
Ted,
Although it is very important to provide your high pressure pump with 60 psi of fuel pressure the High pressure pump can't be forced to flow more fuel than it's own volume.
You can run leaner and more timing on race gas than pump gas so you can make more power on race gas than pump gas.
Ted.
Old 06-14-2018, 06:14 PM   #51
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Ted Have you ever tested these components?
LT4 hi flow injectors lingenfelter
LT4 hi flow pump lingenfelter
Cam w 38% lobe
Dsx Aux pump
This is about all you can do before going to a haltec aux system with 8 more injectors correct?
Would like to be about 900 whp w no meth on e85 pump gas running a flex setup would it work or do you have to go to haltec setup?
Would be using a 2650 rotor design blower.
Thanks,
Ted
Old 06-14-2018, 06:18 PM   #52
JANNETTYRACING
Cam w 38% lobe
Dsx Aux pump
Thanks,
Ted
I have not tested the LPE stuff not within reach for most people but I know they work I seen the results they made like 1500 HP on them.
The DSX stuff is great we sell it.
Ted.
Old 06-15-2018, 06:50 AM   #53
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Ted,
I am always impressed by your knowledge, and willingness to share info let alone your impressive results. You have done such a great deal of tuning with these engines. Thank you!
Jhunsberger is offline   Reply With Quote
Old 06-15-2018, 07:30 AM   #54
JANNETTYRACING
Originally Posted by Jhunsberger View Post
Ted,
Thank you.
Old 06-15-2018, 11:36 AM   #55
chris12
The "Thing"
chris12's Avatar
Drives: 2016 Camaro 2ss,Whipple,R888R,A8
Ted thanks for all the great information. I am planning on going to the camaro fest. Not sure if you will be there or a rep from your company but at any rate keep up the good work. Just to let the newbie to the camro6.com website know that TED is the man. You have always answered all my questions in a timely matter. Even the questions that i thought were stupid. Hope you have a great weekend...
Helping Others
chris12 is offline   Reply With Quote
Old 06-15-2018, 11:57 AM   #56
JANNETTYRACING
We will be there in full force, looking forward to seeing you there.
Thank you for your support.
