#43 |
![]() Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
Who's BAP did you use? I'm thinking of tossing one at my build and hopefully getting meth to be icing on the cake instead vital fuel up top.
#44 |
Drives: Many C7's Join Date: Apr 2014
#45 |
![]() ![]() ![]() ![]() Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
Can anyone tell me the total height of the new ZL1 in tank pump set up? Curious if it will fit in my custom fuel tank
#46 |
![]() ![]() ![]() Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
I'm holding out for a better aftermarket solution. There are plenty of crate LT4s running on aftermarket fuel systems such as these. My inclination would be to either replace the OE pump within the module directly or to simply install an aftermarket assembly independent from the OE - which would remain only for the sender.
See step 18: http://www.superchevy.com/how-to/eng...classic-chevy/ Has anyone looked at the OE module closely enough to determine if the the pump itself could be directly replaced somehow? It seems the other options are to slap on multiple band-aids and points of potential failure for marginal improvement. Wouldn't a voltage booster be as likely to fail and cause catastrophic engine damage as a meth system? Or an overdriven pump?
![]() Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
#47 |
Drives: 2017 50th 2SS Join Date: Jan 2017
I have a zl1 pump in route. When I pull my factory basket out I plan to look at options to upgrade the pump itself. My denali is running a walbro 450 I was able to fit in the factory basket and it supports a ton of power. I have a tvs2300 running as much as 12psi and flow never drops under 50. Zl1 pump is due next week and I'll get into swapping it and post my findings.
#48 |
"See step 18: http://www.superchevy.com/how-to/eng...classic-chevy/"
Seems like a sketchy build.Anyone who attempts to use the tiny heat exchanger they tried at first is lacking knowledge about superchargers. I not convinced that fuel pump is up to the task either . I don't think it can put out the 72 psi needed nor is it returnless. ....maybe. I 'll know more when I get my hands on the Chevy crate engine instructions. |
#49 | |
Please post the instructions when you get them.
#50 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
#51 |
Thanks! That's what I am looking for ....Wish it was an inch longer. |
#52 |
![]() ![]() ![]() ![]() Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
That's what she said! Sorry you pitched that one up.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
#53 |
#54 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
Just curious. Will a 6th Gen ZL1 fuel pump work in a 2010?
Trying to find a drop in solution for my E85 HCI combo...
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
#55 |
Drives: Anything I want Join Date: Oct 2008
#56 |
LSx FTW!!!
