Old 12-31-2016, 01:40 PM   #43
Penley6873
Penley6873's Avatar
Drives: 1973 Z28 & 2016 Red Hot 2SS
Originally Posted by sub_ETCS_ret View Post
How was the balancer bolt?
Sent from my SM-G920V using Tapatalk
Balancer bolt was a little bit of a pain. We used a a 4 ft ish breaker bar and it didnt want to budge. haha Procharger lists the bolt as a 24mm but I PROMISE you its a 15/16. As soon as I stuck the 24mm on it and felt the slack i knew it wouldn't work.
Red Hot/Andrenaline Red 2SS NPP Vossen VFS6
73 Z28 Dark Red Metallic Project
Black 68 Camaro 496 4 Speed
70 Chevelle Pro Street Project
Instagram - tpenley1
Penley6873 is offline   Reply With Quote
Old 12-31-2016, 01:44 PM   #44
Penley6873
Penley6873's Avatar
Originally Posted by GirlyNFG View Post
Awesome. glad you had fun with the install... one thing i always forget... make sure your oil drain from the supercharger is a 90 degree and not straight out... if its straight, call procharger and tell them.
Yeah the oil drain was a 90 degree. It really was a fun install just took a while. We finished around 2am. I drove it to the gas station immediately after we check everything out. The first person I ran into asked me what kind of racket my car was making. I just smiled and said I don't know what that noise is better get it checked out. haha
Old 12-31-2016, 02:33 PM   #45
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
Did you try an impact wrench first by any chance? Trying to decide if I want to do this myself.
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 12-31-2016, 02:35 PM   #46
sub_ETCS_ret
I hear that quiets down after a bit of time. Did you get the helical gear?
Old 12-31-2016, 02:47 PM   #47
Penley6873
Penley6873's Avatar
I couldn't try an impact because with the fan and radiator still in my impact wouldn't fit. & No i just went with the straight cut gears. But, it has quietened down considerably in the 350ish miles I've put on it. It does chatter a little at idle and low RPMs, but after about 1500-1700 rpm it loses all chatter. But that's normal with the straight cut gears.
Old 12-31-2016, 02:51 PM   #48
sub_ETCS_ret
Good to know. I was wondering if a impact wrench would fit in there. Thanks for the info.
Old 01-02-2017, 12:04 PM   #49
sub_ETCS_ret
Did you get it tuned yet? How are you liking it?
Old 01-02-2017, 05:32 PM   #50
chrisx66
chrisx66's Avatar
Drives: 66 Chevelle 8:02 @174
I fit an impact wrench in there but it wouldn't remove the bolt. I heated the bolt head with a torch and it came right off.
chrisx66 is offline   Reply With Quote
Old 01-02-2017, 05:50 PM   #51
Perdieu
Perdieu's Avatar
Drives: 2017 Nightfall Grey Auto 2SS
ding ding winner winner
Perdieu is offline   Reply With Quote
Old 01-02-2017, 06:22 PM   #52
sub_ETCS_ret
Thanks!
Old 01-04-2017, 07:40 AM   #53
Purekoryo
I assume you tried penetrating oil before this as well?
Purekoryo is offline   Reply With Quote
Old 01-20-2017, 10:32 PM   #54
JoshuaHyperblue2ss
Drives: 2016 Hyper Blue 2SS
Just placed my order for stage 2 FMIC with helica gears on Thursday told few weeks to deliver. Will have before after Dynos. I will be 100% stock 8spd. Thanks Tim for the IM Got a great deal from Chris
2016 HyperBlue 2SS, A8, MRC, NPP, Grounds Effect Package.
Performance:
Psc1 Pro-Charger stage 2 FMIC Helica Gears
Aesthetics:
15% 3m Tint all around/phastek full blackout kit
Debaged sides, Tinted inner tail lights, Black Bow Ties, 20 Black 5 spoke rims
JoshuaHyperblue2ss is offline   Reply With Quote
Old 01-21-2017, 02:18 PM   #55
Alexander
Drives: Black 1SS NPP
Im also curious to how people are getting these deals in the 4 thousands with the intercooler upgrade. If I could figure out how to get a deal like that id purchase one tomorrow
Alexander is offline   Reply With Quote
Old 01-21-2017, 02:25 PM   #56
Zack46
Zack46's Avatar
Originally Posted by Perdieu View Post
Save the money on the intake, net gain is not worth it.
Heck even doing a cat delete pipe over the headers would be money well spent if your not going to go all out with the fuel side.
Expect numbers to be in the mid to high 500's. They just did a friends 2017 574/510 on the base tune up stock everything A8
Zack46
Production Sequence Number 98
NEOCC Camaro Club Member
