#43 |
#44 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
60 mph tail wind on a 1,100ft track that faces south and is down hill.
#45 | |
#46 | |
![]() Drives: 2017 Camaro SS Join Date: Aug 2016
If you have isolated before and after dyno results showing something different then please post them up so we can expand our collective knowledge base |
#47 | |
![]() Drives: 2016 Chevy Camaro Join Date: Jun 2016
#48 |
![]() ![]() ![]() Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
One thing about dyno's, the results they produce are not fool proof, change some input variables or even how tightly you lash a car down between pulls and the results can vary on a particular dyno, let alone between different dynos and shops. No doubt a dyno is a great tool to quickly see how incremental changes are effecting your car, but trying to compare different cars and results from different shops could drive you crazy.
#49 | |
#50 | ||
![]() ![]() Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
![]() Quote:
I fixed it for ya ![]() Their is no disputing PRAY has blazed the trail with the recipe for getting close to 10's na, big kudos to you bro. I will be following in your footsteps come spring and I hope to come close to what you have done. I have really given a lot of thought to a gear swap this winter to either a 3.23? or the 3.73, conventional old gearhead thinking is that first gear would be too steep with the M6 rear set and useless..... but this is not your rich uncles Rossler 400 that only has 3 forward gears, and if you harness it then we can really see what the A8 is capable of. I'm gonna step out on a ledge and say the gear swap could possibly net a 1.4 '60 (with a setup like PRAYs) and may no longer require a converter to get you moving.
#51 | |
Even using your 30-40hp (which i struggle with as you wont point to any evidence) That still doesnt sound like good bang for buck when that same 4k would get you most of the way to a supercharger that would be more like 150hp+ add. If the stock headers were a problem then you would expect a supercharged application to show big gains, but the guys that have SC'd and then done headers havent even shown big gains with headers. The OP's question was best bang for buck. $3-400 for a flex fuel sensor to get 30hp vs. $4k for (you claim) 40hp? Thats not anywhere in the same league in terms of bang for buck. |
#52 |
"Lohla"
Save up your money and buy a blower. You'll spend nearly the same money doing full bolt one and you won't have the power that the blower will make. I know it's hard to wait but I've gone the bolt on route and then the blower route and I'll never stay N/A again. The Maggie keeps cool and if you add Meth, it's even better. Prices are going to level out here sooner or later and you'll be able to get into a Maggie for prices that will make it a no brainer.
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
#53 |
Pray with not even FBO, is already in the 10s. More than enough. I tossed around both, glad I went to FBO, more than enough.
Basically even NA the car can be traction limited at an legal speed, the rest is just bragging rights not actual performance.. Plus the numbers don't add up: $900 LT and off road pipe $750 for tune and E85 $55 mod box and green filter $1100 for MSD Free ported TB sub $3000, cheaper if you just port your own manifold now it is below $2000, so much for might as well get a blower cause that is 2 to 3.5x more expensive (that is not "close to the same cost"), and we all know the blower is going to lead to most of the above AND more right?
#54 |
Might wanna checkout QTP cutouts too. They advertise about 17/17 as well...
#55 | |
![]() Quote:
https://www.google.com/url?sa=i&rct=...81811104377170
#56 | |
