Old 12-15-2016, 02:23 AM   #43
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Just installed one tonight, as always crafted a video for it, incoming!!!!
Sledgehammer70 is offline   Reply With Quote
Old 12-15-2016, 09:54 AM   #44
Goobaba
Drives: 2016 V6 RS Manual
I want it!
Goobaba is offline   Reply With Quote
Old 12-15-2016, 10:03 AM   #45
Ace01
Ace01's Avatar
Drives: 2018 1LE SS "Silver Bullet"
Originally Posted by keysersoze View Post
well that's not reassuring. I'll see if I get the same experience when I get mine tomorrow.
Well that sucks!! what did you pay with install? Let us know what they find out
Ace01 is offline   Reply With Quote
Old 12-15-2016, 10:38 AM   #46
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
If you have rough issues, it's likely that air is getting passed the maf. Usually this is because someone forgot to connect or tighten one of the 3 hoses connecting to the intake before the TB, likely the sound tube on the bottom.
Also, your ECM has to relearn everything so I would let it idle for a while until it learns the idle and then shut off and turn back on and drive it nice and gentle through the rpms at first before really getting on it.
Old 12-15-2016, 11:46 AM   #47
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
I was going to say the same thing - sounds like a leak.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 12-16-2016, 09:58 AM   #48
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
upstate...I sent you a Private Message. Please respond when you get a chance. Thanks!
Old 12-16-2016, 10:41 AM   #49
Wildhammer
Wildhammer's Avatar
Drives: 2017 1SS
Please update us Upstate on what the outcome was, I hope it was simple as a incorrect installation =/
Wildhammer is offline   Reply With Quote
Old 12-16-2016, 12:34 PM   #50
GasPipeDreamer
Drives: 2016 Chevy Camaro V6
Originally Posted by upstate View Post
Just had mine installed along with the flash at the dealer today and my check engine is already on after about 5 miles. Idle is EXTREMELY rough like 300RPM variance (700-1000RPM idle swing). When i am coming to a light and try to use the engine to slow the car down it now just keeps the revs/speed stable... Taking it back to the shop in the morning!
I have had this rough idle issue and the feel of the car wanting to turn off when coming to a light because of the low rpm. It was on a previous car I owned that I took to a dealership to get some work done. After I got home I looked to make sure everything was connected and there it was a hose that was not connected. I connected it and added a ziptie to make sure it doesnt come off loose again and bam car ran perfect.
GasPipeDreamer is offline   Reply With Quote
Old 12-16-2016, 01:03 PM   #51
keysersoze
keysersoze's Avatar
Drives: 16 Camaro
Just got my CAI in the mail. I will be installing it tonight and see if I have the same issues.
keysersoze is offline   Reply With Quote
Old 12-16-2016, 02:50 PM   #52
Mitch16
Drives: 2018 Camaro 1SS 6spd
Just ordered mine. Having the Dealer install the intake and relearning the Ecu on the 30th!
Mitch16 is offline   Reply With Quote
Old 12-16-2016, 03:43 PM   #53
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
that's awful considering you pay more than some of the other intakes, GM has to tune it, and problems already???? hopefully its that sound hose.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 12-16-2016, 03:49 PM   #54
Drives: 2016 camaro
it shouldn't take much relearning, considering the flash was done by gm... these are modern computers, not the 70's and 80's era counterparts. our cars sample multiple readings per second and can control a car from spinning out which can take just two seconds, and apply brakes to whichever corner has the slip while still apply abs simultaneously.
getting a CEL 5 miles afterwards, and after a retune BY the dealer?
nahhh, computers adjust on the fly. its 2016.
they'll over and undercompensate for certain conditions, but they fine tune as they go....
Old 12-16-2016, 04:22 PM   #55
cellsafemode
When I reflashed my computer it behaved exactly like you would expect a car that had just been turned on for the first time ever. Idle was high longer than normal, throttle was rough and odd behaving. It took a short while for it to return to what everyone would consider "normal". That was with the ECM reflash as being the only change.
It's not days, but it's definitely more than a Flash and immediately go and you'll be fine kind of change.
Old 12-16-2016, 05:47 PM   #56
CMCamaro
CMCamaro's Avatar
Drives: 2022 Silverado, 3.0 diesel
Can people post what their dealer is quoting/charging them for install? I will be ordering mine in spring and want to make sure my dealer is in the ballpark. I have seen a few numbers on here, but it would help to hear more. I am thinking about installing myself and only going to the dealer for the flash.
CMCamaro is offline   Reply With Quote
