#43 | |
Drives: C7 Z06 manual, 18 Zl1 manual, etc Join Date: Dec 2013
#44 |
![]() Drives: 2016 Chevy Camaro Join Date: Jun 2016
Here's your cam...
https://www.briantooleyracing.com/su...fuel-lobe.html As for the compression, we have 11.5:1 to begin with so you're fine on that end. Ported heads? It's a matter if 25-50hp means a lot to you. That blower solves alot of problems... |
#45 | |
#46 |
Yes , my opinion is this one would be better suited for your build based on what I see. When I speak about cams, it's drivability first, hp second ,100% of the time. You just went and spent $50k on a new car. So I'm willing to bet you would not want to sacrifice drivability that's associated with big duration cams... By you having a stick car helps a lot but ,too much duration doesn't help your blower. Also it's a 235 duration which moves the power band higher. An example would be let's say a 224/224 has a range of 2000-6500. Well my guess on yours would be 2800-7000. That's not to say it's not a great cam at all. Most of them are but it's probably better suited in a 416ci. Then there's the 1.7 issue. Just seeing that means get your money back if this is actually correct. On a 1.8, that would put you at a .680 lift... So basically my theory is because this will be a daily driver, this isn't the cam for you. If you planned on making it a weekend warrior then of course. Hell , your cam specs aren't too far away from the new COPO camaro... Hopefully I was helpful...
#47 | |
#48 | |
#49 |
![]() ![]() ![]() Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
I thought the decreased compression came from the increased chamber volume of the LT4 heads, and the pistons only had a slightly different head configuration?
![]() Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
#50 |
He probably referred to the LT4's comp ratio when he said it. I could've not heard exactly correct. Basically coming down a point in compression would be beneficial...
#51 |
Ok guys here's the skinny! Just got back from the builder and went over the last 2 pages of this thread with him. Once more good catch and a huge thanks for chiming in and catching this glitch. Anywho as for right now I am going to contact Vengence tomorrow (closed today) and see about exchanging the lt1 slugs for lt4 slugs as they are still in box unused, and swap out that cam as well to a cam they have that is comparable to the btr cam blk16ss recommended. The rocker arm issue is in the air til tomorrow as well as they are closed today. If they exchange slugs and cam this will obviously take care of that concern. I am on the fence as we speak on head porting and snout and tb porting as my budget is starting to get stretched more and more and so far I've not used any plastic. If I can play with the numbers (financially) and squeeze out another 2k then I will probably go ahead and do it. If not I'll have to make do with what I have bc I still have a tune, heat exchanger, cold air intake, plugs, and ice box to pay for (already in budget). Only issue I see in the immediate future are clutch, axles, drive shaft. This will come in spring hopefully when I get the piggy bank a lil more filled meanwhile my out dated kitchen is begging for a remod but I can't drive a kitchen is how I look at it. Soooo, pretty much looks like I'm on hold for another 2 weeks at best. This is borderline torture guys (waiting, and spending $)
#52 |
Good deal... The right cam will solve your rocker arm issue. Just ask for a piston set that would lower your comp ratio from 11.5 to 10:1-10.5:1...
#53 |
Thanks again man, Very good advice now after swapping pistons and cams this should be half ass decent. Almost sure on the heads and snout and blower porting but not 100% as of yet. Tomorrow I'll know
#54 |
More down time fella's lol. Heads going out Thursday to get ported, might port tb and snout while I'm at it tbh. They are calling for a 2 week turn around, By now I'm going to venture and say it's probably going to be another month. So much for a simple build. Beginning to wish I'd just tossed on headers and exhaust and called it a day, Car has been down longer than it's been in existence.
#55 | |
Drives: Anything I want Join Date: Oct 2008
#56 |
![]() ![]() ![]() ![]() ![]() Drives: 18 Silverado 1500 Join Date: Dec 2015
