#43 | |
![]() Drives: 2017 Camaro 2SS Join Date: Dec 2016
#44 | |
![]() Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
#45 | |
One other question...kind of off topic... Has anyone hooked up a wideband to the P3? What all is needed to do so? Do I need a wideband sensor and controller, just the sensor...etc? Thanks! |
#46 |
![]() Drives: 2018 Camaro 2SS, Hyper Blue Join Date: Jun 2016
Has anyone re calibrated the CAN bus configuration for their instrument cluster once the map sensor was installed giving a vac/boost reading back to the ecm? I ask because I hooked the scanner to my 18 SS and I'm able to pull up the vac/boost gauge through the instrument cluster module but there is no signal for it to allow the gauge to stay.
I'll know once I get the Lt4 supercharger conversion completed in the next few weeks. If someone is in the Chicagoland area with a supercharger setup, I would try it on yours to verify.
2018 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue, LT4 S/C, LT4 Fuel System, RotoFab CAI, Headers, HiFlo Cats
2016 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue (GM buyback) 1999 Trans Am Firehawk, M6, headers, no-cats, slp exhaust, hot cam, intake, 3:73 gears. Red/Blk |
#47 |
way back people were using a MAF signal to break-out into led that were set into the instrument cluster. I've lost the circuit diagram but it was popular with Honda, VW and Audi people. I was a simple voltage breakdown ladder with zeinner diodes.
I'm using two simple hobs switches 1 set for 4 PSI and turns on green leds that are set into my hood vent / extractor, the 2nd hobbs set for 7 PSI (overboost for me). I was thinking of LED skulls in the hood extractor, saw it at Autozone, one with green eyes and the other with red (passenger side extractor). Too bling but I really liked it.... still tossing it around. Car is to fast for a gauge anyway. Hence I just went to LED lights. Here is an example of an Audi LED light setup: https://www.audiworld.com/tech/elec42.shtml The ones I've seen and done were all in the instrument cluster, this guy put his on the steering column. I have the LED on my hood extractor, but you get the idea.
