Old 11-09-2016, 06:04 AM   #43
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Originally Posted by crankaholic View Post
it's definitely way better than a 4th gen. I was comparing mine to my previous car with an all aluminum rear subframe/suspension with stiff poly bushings. I like my sports cars to be stiff and communicative, the stock 2SS rear end is more GT car though... a very good and well sorted GT car that puts the smackdown on an M4
Thanks!
Old 11-09-2016, 09:33 AM   #44
cwl011
You also have to pay attention to the weather, the other day it was in the 50s and the rear end got a little squirrely on me. However, when the tire are warm it sticks to the ground and I haven't broke loose unless i wanted to.
cwl011 is offline   Reply With Quote
Old 12-24-2019, 11:37 AM   #45
Tubtub
Drives: 2019 Chevrolet Camaro 1SS 1LE
2019 1LE and I have noticed a sensation like this under hard acceleration the back end seems to float/ move around even though I'm not breaking loose. It's scary as hell, I'm going to try to take it in. Problem is that it's difficult to replicate. Noticed only after I put my winter wheels/tires on.
Tubtub is offline   Reply With Quote
Old 12-24-2019, 11:51 AM   #46
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Owning a ZL1 even makes it worse especially in the rain or cold conditions! Those GY Supercar tires don’t want to grip the road!
Old 12-24-2019, 12:34 PM   #47
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
What axis are you feeling the movement on?
If it's lateral movement, it's the rear rubber cradle bushings.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 12-24-2019, 12:37 PM   #48
MackSteelPrivateEye
It fish tails because the wheels are spinning. How do you know your wheels are not spinning? Its what causes the FT.
Old 12-24-2019, 01:01 PM   #49
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
I would say it’s not normal if your back end is not breaking lose.
Majority of the time traction control off.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 12-24-2019, 01:11 PM   #50
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
My 1SS non mag ride convertible (which I traded in) was solid as a rock. Zero pull, wander... nothing. This was down to 45F w/ stock Goodyear run flats.
The ZL1 is another story, scary wander / floating sensation @ full throttle and cooler pavement temps ~ 65 - 70F. This improves 50% when the tires are hot. This happens all the way up to 90 MPH, so the tires are not slipping.
I personally think it's a tire issue or the factory alignment, possibly one of the rear wheels toe is out just a smidge. I'll be bringing the car to someone familiar with high powered cars / alignment in the spring (for evaluation).
Old 12-25-2019, 03:04 AM   #51
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
mine would do that but it was the rubber cradle bushings. BMR delrin bushings solved that.
Old 12-25-2019, 11:06 PM   #52
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
It's especially normal for a Mustang at Cars 'n Coffee.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
