Old 09-23-2016, 01:50 PM   #43
nbryant
nbryant's Avatar
Drives: 2016 2SS Red Hot
Originally Posted by keysersoze View Post
Wow that is a bad **** up on GMs part. FML.
Not really. Like most of these industries they rely on vendors. Sounds as if in this case they may have identified a flaw in parts provided by a vendor and are working to fix it and are beginning to work the logistics of replacing them as necessary. It happens. I have been working in aviation (military) my whole life and even in that community they will find parts that don't meet spec and will work replacing them. Depending on the impact, some quickly others in time when the parts are available.
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter
nbryant is offline   Reply With Quote
Old 09-23-2016, 02:02 PM   #44
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
So, figure 3 months or so until they have production from a supplier...
Guess i'll have to flash back to stock in case they need to play with the TCM after having the trans out. Meh.
Leaving everything else on since they shouldn't need to play around with the top of the motor.
Old 09-28-2016, 03:11 PM   #45
Castillojp86
K-Camaro
Drives: 2016 V6 1LT
Originally Posted by osubuckeye View Post
Took my car into the dealer for the water recall and inspection. Dealer told me they had to order the parts. Still waiting after 3 weeks.
Me too! This sucks ass!
Castillojp86 is offline   Reply With Quote
Old 10-17-2016, 02:16 PM   #46
keysersoze
keysersoze's Avatar
Drives: 16 Camaro
I'm at the dealership now and they're addressing the TSB I'll find out what exactly is done once the work is finished
keysersoze is offline   Reply With Quote
Old 10-24-2016, 09:20 AM   #47
devsfan1830
Drives: 2016 Camaro LT - Blue Velvet
I just got back from the dealer for another issue with mine (seat cover pulling away from seat lever) and they also noticed this "recall" and performed the update for me. Now this has me concerned that there is going to be what will be my THIRD recall after the fan connector water thing and my rear toe links. If anyone has sorted out what this is, what this software update was supposed to do and if we're looking a big transmission repair please leave a post. This is not looking good and I am NOT going to like if if my transmission craps the bed out of nowhere on a 6 month old car.
devsfan1830 is offline   Reply With Quote
Old 10-24-2016, 09:21 AM   #48
devsfan1830
I would call them and ask. Its possible someone dropped the ball and the parts are in and waiting. In my case my service advisor up and quit and did not tell anyone about pending part orders. So they were sitting there for weeks until I called and asked where the hell they were.
Old 10-29-2016, 08:42 PM   #49
camaro1&6
Drives: 67camaro 69Nova C6
Yeah I'm on my 2nd transmission and 2nd 1 is also acting up
camaro1&6 is offline   Reply With Quote
Old 01-10-2017, 04:25 PM   #50
Dayle1
Drives: 2016 Hyper blue coupe V6/auto
Went in for an oil change and the service agent informed me about this recall. He said they would need to order the parts then schedule another visit. A web search using my VIN showed nothing so I asked another agent and he provided a print out as follows:
Campaign # 33110 dated: 9/16/2016 status: open
Desc: When a commanded shift occurs outside of the expected transmission turbine speed window limits, the commanded shift monitor requests a driver defaulted 8th gear state. The torque associated with the default action results in broken turbine shaft. The calibration window (based on output speed) for the safety monitor (P16F3) is smaller than the calibration window for the driver initiated tap downshift speed limit checks.
Repair: Reprogram the transmission control module.
So, it sounds like there is a lot of dealer confusion. The reprogram should have been done today and should be all that is needed for vehicles that have not had a failure. Replacement parts and transmission removal should only be needed if the driver is having problems and the shaft has failed.
Guess I will have to call the dealer back to confirm this.
Dayle1 is offline   Reply With Quote
Old 01-10-2017, 04:46 PM   #51
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
What are symptoms of a bad turbine? My tranny is slipping
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 01-10-2017, 05:19 PM   #52
Dayle1
V6 only if I understand correctly.
Old 01-10-2017, 05:40 PM   #53
TMasticTB91
Tampa Bay Camaros
TMasticTB91's Avatar
Drives: '16 Hyper Blue 1LT
Yeah, what parts? Last time mine was in they just reprogrammed it, nothing physically gets replaced unless it actually breaks.
2016 Camaro 1LT | V6 | A8 | Hyper Blue
TMasticTB91 is offline   Reply With Quote
Old 01-10-2017, 06:02 PM   #54
vet757
vet757's Avatar
Drives: ^^^This
Is this service update still active?
vet757 is offline   Reply With Quote
Old 01-10-2017, 07:08 PM   #55
Dayle1
Yes it shows the following:
Expiration date: Unlimited
Status: Open
Old 01-10-2017, 07:15 PM   #56
vet757
vet757's Avatar
Drives: ^^^This
Status: Open
Awesome thanks
