#43 |
![]() Drives: 16 2SS Join Date: Jul 2016
#44 | |
yeah I was a little nervous after my first attempt at putting the box in the trunk, I actually removed the rubber gasket seal at the top part of the trunk to get it in. But hey it fits and that's all that matters. Just a hunch, but I bet you will be adding another amp and replacing speakers soon!!!!!! Matt |
#45 |
![]() Drives: 2016 Camaro 2SS Join Date: Sep 2015
any updates on your completed install?
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
#46 |
Sorry haven't posted any updates, been really busy with work since storm Hermine. My work has a satellite office in Tallahassee so that's had a lot of my time. Getting caught up now and should have some updates coming soon. I do have a couple things I want to share.
Matt |
#47 |
#48 |
What did you make the door 6.5 adapter out of. You were right about upgrading after that sub. Just picked up a xd400/4 and trying to figure out what I am going to do. I am thinking I might run just the 4 front speakers off it. Not sure though. Going to run the factory bose speakers until I kill them or after a few months I'll upgrade. It seems the doors are mostly bass and the mids/highs are coming from those small speakers in the dash.
Kooks ceramic coated headers -1 7/8 in. x 3 in
Pray ported 95MM TB Pray ported MSD IM Rotofab CAI BTR 225 CAM PRC 312 CC Ported Heads Katech Oil Pump DSX Flex Fuel E-85 kit QTP exhaust cutouts Full JLAudio Stereo Build w/ 13-W6 |
#49 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
I thought all of the speakers in the sixth gen mounted to the plastic interior panels rather than the exterior body. I guess that is wrong.
Right now my stock bose setup is vibrating all the interior plastic panels. So my first mod will be fixing that issue before upgrading speakers or adding amps after the Bose. I assume there is no after market solution for the proprietary audio protocol in order to replace the Bose amp? |
#50 | |
Matt |
#51 | |
#52 |
can you post info for your entire install? Equipment used/observations/etc? I knew you were experimenting with different things..
#53 |
![]() Drives: White LT, V6, Auto, RS Join Date: Oct 2016
The OEM door speakers are 6x9 but I made a similar choice and used 6.25 Focals in door with tweeter flush below door handle and switches. There is a lot of depth available. I'm putting 6x9s in rear deck and I will not use rear quarter panel speakers. Also put sub in spare well. Should finish this weekend.
#54 |
![]() Drives: 99 M3, 04 STi, 16 2SS Join Date: Oct 2016
I have a new 2SS on its way tomorrow. Interested in a little guidance about options re: the speaker situation. I have very little interest in sticking with 6x9s anywhere really since the upgrade path there for anything good quality is highly limited. I also don't have interest in rear fill and would likely get rid of the rear side panel speakers.
Goal: Full range 6" or 7" components (or coaxials) for the front. Eliminate rear fill. Replace whatever is in the rear deck with free air bass drivers. I don't need the system to be super loud. More concerned with improving the quality. If the outputs from the bose amp are full range, I might be content enough, initially at least, keeping the bose amp and oem wiring and just swapping out the speakers. However, i was under the impression that bose systems usually had some frequency response shaping to improve the sound of their junky speakers. True? How does one get around this issue other than using a DSP of some kind on the speaker level outputs from the bose amp? Very interested in the harness option that was discussed earlier in the thread as well. Can anyone describe this solution a bit better for a newb, please? Also, any more information about what is in the rear deck would be helpful. Am I correct in thinking that those are 6x9s too? |
#55 |
I'd be willing to bet that this is what is needed
http://www.crutchfield.com/p_120MOST...5298585&awdv=c No? |
#56 | |
![]() Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
