Old 03-07-2017, 03:44 PM   #43
F1FTY
Drives: 2018 ZL1
Originally Posted by glenB View Post
Measure the swaybars please
What measurements would you like to see? Thought the diameters have been posted?
F1FTY is offline   Reply With Quote
Old 03-07-2017, 03:45 PM   #44
F1FTY
Drives: 2018 ZL1
Originally Posted by Eric SS View Post
That's great. Looking forward to seeing this. When are you planning on getting it installed?
After I get the summer tires back on the car so most likely late this month, early April.
Heres the kit with the rear trailing arms too:
Old 03-07-2017, 07:33 PM   #45
jaymsu
Yeti's Daddy
jaymsu's Avatar
Drives: ATS-V, Prowler, M6 V10
Looking forward to hearing your review ,comparing it to stock.
I'm debating between full 1LE suspension upgrade vs. just the sway bars for front/rear.
I expect full setup should perform better but the cost difference is more than $1,000 between those two so I'm anxious to hear the real user's reviews on this upgrade.
2SS Nightfall Grey /Adrenaline red interior
NPP / MRC / Nav / 6 Spd
1100: 7/27/15 <SSWNNN>
3000: 9/04/15 <TPW:10/19/15>
3800: 10/19/15 <VIN: 117740>
6000: 12/16/15
jaymsu is offline   Reply With Quote
Old 03-07-2017, 08:10 PM   #46
F1FTY
Drives: 2018 ZL1
For what it's worth:
The 1LE front bar measures in at 3 and 7/8 inches circumference and is hollow.
The 1LE rear bar measures in at 3 and 4/8 inches circumference and is solid.
To turn circumference to diameter, divide by Pi.
1LE Hollow Front bar = 1.233450808962189 inches
1LE Solid Rear bar = 1.1140846016432675 inches
Convert to mm:
1LE Hollow Front bar = 31.3296505476396 mm
1LE Solid Rear bar = 28.29774888173899 mm
Feel free to correct my math as I used google calculators.
Edit: Seeing that Mountain got 30.3mm on his front bar using a more accurate measurement tool. If that variance holds true, size down my numbers by 1mm.
Old 03-07-2017, 08:13 PM   #47
JeromeS13
Drives: 2017 1SS/1LE
Originally Posted by F1FTY View Post
For what its' worth:
The 1LE front bar measures in at 3 and 7/8 an inch circumference and is hollow.
The 1LE rear bar measures in at 3 and 4/8 an inch circumference and is solid.
Front bar = 1.1140846016432675 inches
Rear bar = 1.233450808962189 inches
Convert to mm:
Front bar = 28.29774888173899 mm
Rear bar = 31.3296505476396 mm
How did you end up with calculating a smaller front bar, if the front bar has a larger circumference?
Old 03-07-2017, 08:19 PM   #48
F1FTY
Drives: 2018 ZL1
Copy and paste error, fixed the post
Old 03-07-2017, 08:32 PM   #49
F1FTY
Drives: 2018 ZL1
Now someone who knows the wall thickness of the front hollow bar may be able to help us along in determining the effective rate of the bars.
https://swayaway.com/tech-room/torsi...te-calculator/
1LE Solid rear swaybar is 324.8 lbs/in according to this calculator and loose 11", 41" measurements.
Old 03-07-2017, 09:33 PM   #50
glenB
Drives: Chevrolet Camaro SS
Convert to mm:
Thank you. I know they were measured before but it's kinda like measure twice cut once thing. Also I was under the impression that they were both solid, now we know.
With the front bar being hollow and roughly 1.25", the BMR front bar is also 1.25", and the first hole is 62% over the SS. So I need to measure wall thickness or ask BMR. FYI, the rear bar is also 1.25 and hollow.
glenB is offline   Reply With Quote
Old 03-07-2017, 09:39 PM   #51
F1FTY
Drives: 2018 ZL1
Anytime!
The front bar is definitely hollow, it's extremely light in comparison to the rear bar despite being larger diameter. Want me to weigh the bars?
Old 03-07-2017, 09:43 PM   #52
glenB
Anytime!
No, I'm good, but thanks for the offer and the measurements
Old 03-08-2017, 01:40 PM   #53
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
Purchased but not installed yet. Will take measurements of ride height differences.
Thank you!
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 03-08-2017, 10:42 PM   #54
F1FTY
Drives: 2018 ZL1
Originally Posted by bpang1234 View Post
Thank you!
Anytime!
Biggest question I have now is what are the spring rates??
We know the SS rates. Need to know the 1LE rates.
Looked at buying a spring rate tester but they're expensive.
Old 03-09-2017, 06:48 AM   #55
glenB
Anytime!
Don't let the cost stop you, inquiring minds want to know.
Do you have any roundy-rounders with well equipped shops?
Old 03-09-2017, 09:52 AM   #56
F1FTY
Drives: 2018 ZL1
Haha, that's $895 I could spend towards the six piston brakes.
There probably is a shop around D.C. that has this capability. Just not sure whom. If anyone can find one, I'll take them there to have the springs measured.
