#43 | |
![]() ![]() ![]() Drives: 2016 V6 RS Camaro 6MT Join Date: Aug 2015
That said isn't the PCV tube the left circle in the picture I posted at the top of the page? It seems to be a tube from both heads that dumps back into the intake. I'm not extremely knowledgeable or experienced with vehicle mechanics so I'm probably wrong - but that is my best guess for whatever that is.
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
#44 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
http://www.camaro6.com/forums/showthread.php?t=458507
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
#45 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
That's great for the 2.0. They started working on the V6 before that and have come back with absolutely nothing. As far as the PCV tube, nothing connected to the intake tube in front of the throttle body is a PCV tube. If it is, then no oil is getting into our intakes via the PCV line because my intake tube is bone dry and clean and so is the TB. |
#46 | |
Also, when I removed the tbodies this week there was an oil film inside. Especially on the backside of the blade along the bore. Just posted the 2.0 thread, cause granted no catch can is car specific, the hoses and routing may have to be. But like someone said., no v6s have been in for development. Well see though.
#47 |
I can check mine this weekend. If it's oily I'll put the catch can I bought a while ago on.
#48 |
If ya don't mind post up where ya tap into
#49 |
OK so I didn't see any oil but I did notice some carbon buildup around the throttle body opening.
I have an eBay catch can for 20 bucks and I didn't want to permanently attach it so it is secured by zip ties for now. I have just under 3k miles right now. Pictures below of install. |
#50 |
This is temporary obviously. If I see fluid in this thing I'll get a better can.
#51 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LS M6 Inferno Orange Join Date: May 2010
An ebay catch can is better than nothing I guess, but... LOL!
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers Find me on Facebook: http://www.facebook.com/gahammerle |
#52 |
![]() ![]() ![]() ![]() ![]() Drives: Gen 6 Camaro RS Join Date: Dec 2015
i like those blue tubes!
#53 | |
I'm still not convinced from 1 car that there is a problem, let alone one that can be solved by a catch can. In other words, if it's just a carbon problem then the lack of oil will still have it travel all the way to where there is oil (valves etc) before getting captured out of the intake air, still leading to buildup despite the catch can. As you can see from the intake pictures, the plastic portion of the intake is bone dry and clean where the pcv is connected. Perhaps because the plastic doesn't bond to the carbon well since I do see carbon buildup on the metal throttle body. I guess i'll find out. |
#54 |
![]() ![]() ![]() Drives: 16 Camaro, 11 Stryker, 00 Explorer Join Date: Dec 2015
Just incase you haven't figured it out yet, naturally aspirated means that it doesnt have forced induction (turbo or super charger). The only Camaros that are not N/A right now are the 4 cylinder (turbo charged) and the ZL1 (super charged).
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015 3000 1/8/2016 (TPW 2/1) 3800 2/1/2016 5000 3/5/2016 |
#55 | |||
Drives: Mostly Stock Join Date: Jul 2012
#56 |
Well i've got mine hooked in, driving it ...we'll say spirited.. around. Nothing showing up yet but I'd expect it would take hundreds, if not a thousand miles to start showing up at the bottom of the indicator tube if it shows up at all.
