03-31-2016, 11:40 AM | #43 |
Drives: 2010 SS L99 IOM Join Date: Aug 2012
Maybe DOHC.
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins |
04-06-2016, 06:44 PM | #44 |
Drives: Want a gen 6 Join Date: Jan 2013
I read somewhere that they are dropping the LS7 in the new Z/28.
I did not think that was going to happen, but I did see it somewhere that may not be reliable. http://corvettec7fiasco.blogspot.com...continues.html |
04-06-2016, 06:59 PM | #45 | |
Drives: 2017 1SS 1LE Join Date: Sep 2014
04-13-2016, 08:39 PM | #46 |
Drives: 2001 Onyx Black/Ebony SS. 427/M6 Join Date: Apr 2016
To me, the de-stroked LS7 has been around for about 5 years now. I'd like to see some version of this. Whether using the LS7 or the LT1. Between GM's racing experience, the performance divisions experience and seeing what the aftermarket can accomplish, it should be a breeze.
http://www.superchevy.com/how-to/vem...oke-of-genius/ http://www.superchevy.com/how-to/eng...ring-corvette/ http://www.hotrod.com/how-to/4-8l-cr...pm-ls-stroker/ |
04-13-2016, 09:19 PM | #47 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
I just don't get the infatuation with N/A engines. I personally like reliable power. It is much easier to keep everything cool when you are driving around with 500 N/A hp than when you are compressing air and making 650 to 700 hp. PD superchargers make just as instant and linear power as N/A but take a little more engineering to keep cool and the supercharger driven off a belt eats some of the power gain and makes it less fuel efficient. Turbos are more efficient but the power can be less controllable when it comes on. Turbos continue to get better. No one in Indy cars or F1 says they wish they had an N/A engine. We just need to get the best race tech turbos/motors to work down to street cars. I personally am hopeful that GM is working on this very thing for the next Z/28.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
04-13-2016, 09:40 PM | #48 |
Drives: None Join Date: Feb 2016
Uuuum, I think you just answered on your own about why people are infatuated with NA engines. Traditionally, FI motors are harder to cool, heavier, less consistent, and less linear in the case of turbos. They can be cooled and engineered for endurance, but at greater expense and/or weight.
I also think that FI takes away from the character of engines. If everyone uses FI, it sort of muddles everything together across all car brands. Much of the individual personalities of different engines are lost. I've had just about every combination of engine available: turbo, PD blower, high winding NA, 4 cylinder, rotary, V8, and a few more I'm sure. I've come to enjoy my NA engines more than anything else. Besides, how much more power do you need for a road course car than what NA motors make anyway? |
04-14-2016, 09:32 AM | #49 | |
04-14-2016, 09:51 AM | #50 | |
I used to be Dragoneye...
In any event, the problem has largely been addressed, thank goodness. |
04-14-2016, 10:03 AM | #51 | |
Drives: Current Camaro-less Join Date: Jul 2014
However, it is dramatically less capable and reliably making that power. FI motors heat-soak, and are more heat sensitive than N/A motors, no matter how many intercoolers, radiators and other equipment you strap to it. You can't point to F1 or Indycar and say "look they can do it!"...I mean..after all..NHRA top fuel produces 10,000 HP on 500CI Hemi's with a blower..that means there's no reason a street car can't do that, right? |
04-14-2016, 10:08 AM | #52 | |
I love all these "It's going to have the LS7" but provide no proof, no citation, no nothing to back it up. I heard the Z/28 is going to have reproduction cross-ram 426 Hemi's in them!! (does that make it true? no, but it's the same level of authority as all these other LS7 rumors) |
04-14-2016, 11:47 AM | #53 |
4 new ZO6 where out with me at Big Willow track ( fun track ), like we said before 3 of the 4 left on a flatbed trucks, and not the way they came in, the forth overheated but was able to drive it home, now this is 20 min runs in 75+ degree days, this is not a good car for the track IMO.
04-14-2016, 12:20 PM | #54 | |
Drives: 2014 Z/28; 2014 Ram 2500 CTD Join Date: Jan 2014
2015 Silverado 2500
2014 Z/28 |
04-14-2016, 01:06 PM | #55 | |
Anyways, the early Z06's were having issues. They've made changes to the cooling systems to correct the issue since then. Cooling is as much a function of the vehicle's design as it is the engine. The Camaro has the benefit of more airflow than the Corvette...a FI engine could work... Overheating is not solely a result of FI. Sure, the extra pressure is a challenge, but naturally aspirated engines can have issues, too....heat is directly related to power. More power = more heat...if you don't cool it, stuff goes wrong, doesn't matter if there's a blower, turbos, or not. Some GT350's has had some issues, too...and that car has a "racing engine". |
04-14-2016, 01:32 PM | #56 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
The GT350's issues were not related to engine heat, but transmission heat. As far as I can tell, there haven't been any issues with GT350s that have overheated with the track pack. It does seem the engine vibrations are causing havoc with the oiling system. Four GT350s on Mustang6g alone have had engine failures that seem to be caused by lack of oil pressure. I agree the Camaro may have a better chance at keeping the LT4 cool, but I don't know if I would want to bank $60k+ on that.
