Old 07-01-2017, 11:03 PM   #43
RojellyB
Drives: 2016 1LT NGM
^^ just feel around for the door. I just changed mine two days ago
RojellyB is offline   Reply With Quote
Old 07-02-2017, 10:44 AM   #44
wal-dog
Drives: 2016 Garnet Red 1SS
Originally Posted by Michigan1LTRS View Post
Look up, there is a mini door that has to come off.
Thanks. Fixed my images. Photobucket no longer free. It seems like its all one peice. Don't see a door.
wal-dog is offline   Reply With Quote
Old 07-02-2017, 10:54 AM   #45
GOMD
GOMD's Avatar
Drives: 2017 Camaro 1SS, 2023 Sierra
Your pictures do not show the door, you need to get lower and look upwards above the solid piece with the 2 holes. Look back at the original post with pictures to compare.
GOMD is offline   Reply With Quote
Old 07-02-2017, 10:55 AM   #46
wal-dog
Just checked again. Can't find a door. Can the door be seen in the picture?
Old 07-02-2017, 10:56 AM   #47
wal-dog
Ok. I'll go check
Old 07-02-2017, 10:56 AM   #48
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Look up higher....it's there......
Old 07-02-2017, 11:07 AM   #49
wal-dog
Found it! Thanks guys. 20k miles.
Old 07-02-2017, 11:10 AM   #50
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Give it a couple mild spritzes of fabreze (non scented) before you slide it back in....
Old 07-02-2017, 11:13 AM   #51
wal-dog
Ok will do
Old 09-24-2017, 03:03 PM   #52
Omar1
Drives: 2016 2SS Red Hot
What a pain in the ass this was.. Couldnt get the pegs out. Thought i was about to break the damn thing.
2SS Red Hot 6 Speed, NPP, MRC, 5 sploke black low-gloss, glow-tie
Omar1 is offline   Reply With Quote
Old 09-29-2017, 02:36 PM   #53
davet435
davet
davet435's Avatar
Drives: 2016 2SS Mosaic Black
Send a message via Yahoo to davet435
Glad I found this post. I didn't find anything else on the Internet. No YouTube videos, nothing at all. I haven't been on this forum in quite a while. Should have known the answer would be here.
It is a pain. Fortunately I had a clamp that I got at HF to hold 2x4s together so they don't warp and that was the perfect tool for squeezing the glovebox.
Finished and realized I had forgotten to spray with new car or learpther scent. I guess that clamp makes it easy enough to pull it back out.
Replacement car ordered 2/02/2016
2/03/16 2500
2/04/16 3000 no TPW
2/8/16 3000 TPW 2/29
2/18/16 3400
3/3/16 3800
3/4/16 4B00
3/5/16 4300
3/7/16 4200!!!
davet435 is offline   Reply With Quote
Old 09-29-2017, 03:09 PM   #54
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Sorry, I dont make youtube videos. i find the whole home-style videos on there to be pretentious/narcissistic and I dont have the time to go pro. So forum posts it is.
Old 09-29-2017, 03:28 PM   #55
davet435
davet
davet435's Avatar
I don't make YouTube videos either. It just surprised me there weren't any. As I mentioned I'm glad this post was here. It was extremely helpful. Actually that was the second place I looked because it's a common place for them but when I couldn't squeeze the glovebox I assumed it wasn't there.
Again really appreciate the post. Very helpful.
2/03/16 2500
2/04/16 3000 no TPW
2/18/16 3400
3/3/16 3800
3/4/16 4B00
3/5/16 4300
3/7/16 4200!!!
Old 10-22-2017, 06:48 AM   #56
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
People are making this harder then it has to be. Empty glove box, on the right side slide clip forward to unhook, use a wonder bar (one inch wide pry bar) and place directly in middle of the left edge of box and put just enough pressure to visibly see the one inch wide "block" clear the lip that holds it in place, keep just enough pressure to keep from falling back in place and do the same on the right side. Once you clear the lip on the right side the box will swing down. There are two clips on the bottom of the filter cover that hold it in place, unclip and pull out cover, change filter and reverse. It took longer to empty the glove box then to change the filter.
dpevans is offline   Reply With Quote
