02-16-2016, 09:05 AM | #43 | |
Drives: 2016 Camaro 2SS White/White Join Date: Jan 2010
[QUOTE=Blackdevil77;8906633][QUOTE=doc212121;8906616]
Glad you got rid of the GT500, go scoop up a 6th gen so you can get involved first hand! |
02-16-2016, 09:23 AM | #44 | |
Drives: 21 Bronco Join Date: Jun 2012
What I meant was if they do a Z/28 again, I would think they might want to give the consumer a little more choice. Instead of the only options being A/C and radio maybe they will offer a package with a bit more creature comforts. Yes I understand that it is built for the track, but more choices never hurt anyone. Just look at the Z06. You can get it with all the creature comforts they have to offer and still get the Z07 package |
02-16-2016, 09:28 AM | #45 | |
Drives: 2008 Pontiac G8 GT, Shelby GT500 Join Date: Mar 2011
[QUOTE=doc212121;8906669][QUOTE=Blackdevil77;8906633]
I plan to jump on 6th gen bandwagon. I'm waiting on a 1LE SS. |
02-16-2016, 09:50 AM | #46 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
02-16-2016, 10:01 AM | #47 |
Got ya. Yeah that was what I meant. More creature comforts for the top model. and maybe an option with more street friendly tires lol
02-16-2016, 10:30 AM | #48 | |
I used to be Dragoneye...
What will be curious to see is the engine they choose. The days of N/A high-horsepower are virtually over. The LS7 was on life-support most of its life because it couldn't pass emissions tests.... But......before you write off the ZL1...consider that the 1LE already has the "big heavy brakes". So all that will be added to the front end of the car in terms of weight is 50 pound worth of supercharger components...and the bulk of the engine is mounted behind the front axle. I expect the new ZL1 to be very well-balanced. |
02-16-2016, 09:19 PM | #49 |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
But will there be a ZL1? Not stated in the affirmative according to this video http://youtu.be/MLPvxA131t0
-CRT Sent from my iPad using Tapatalk
02-16-2016, 09:25 PM | #50 | |
But they're working on something else..... |
02-16-2016, 09:47 PM | #51 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
02-16-2016, 10:10 PM | #52 |
Drives: 2016 camaro ss Join Date: Oct 2015
should be interesting given the price difference between the mustang and the 1LE
Summit white, 2SS, Ceramic white interior, 6 piston brakes, Black Bowties, 6 Speed,3.9 sec 0to60 NPP,MRC,NAV,RX Catch can
02-16-2016, 10:13 PM | #53 | |
(These are rounded retail prices from Chevy performance) LS3: $7500 LT1: $10500 LSA: $13500 LT4: $15000 LS7: $15800 If turning an "LS" engine block into an LS7 cost $8000 more than an LS3...what would it cost to do that to an LT1? Interestingly...I think people don't need to look very far to find out why the SS Camaro costs more than last generation...The LT1 retails for $3000 more than the LS3... |
02-16-2016, 10:36 PM | #54 | |
That's why I think going with an LS6-like version of the LTx makes the most sense. The LS6 wasn't much more expensive despite the 15% increase in output over the LS1. Looking at the torque curve of the LT1, it hits a wall at 4,800 rpm and drops off relatively quickly. Find a way to carry it higher in the rpm range and you will have almost the same power and torque as the LS7 without the cost. I'm curious as to what the LT1 costs GM over the LS3. The LT4 is almost $6k cheaper than the LS9. I imagine an LT1 based hi po engine would be cheaper than the LS7 by a similar amount.
02-17-2016, 12:09 AM | #55 | |||
Moderator.ca
To the next person that replies to one of the string of broken quotes ...
please type ' [/quote] ' before writing the rest of your post. Quote:
Every engine needs to be certified for emissions, fuel economy, and (due to GM's own personal preference), power. And are all the cars going to be built with the 'heavy duty' hardware of the most powerful engine -making the cars heavier than they need to be? Or will each car get appropriately robust transmissions, dif, and axles -driving up the costs of everything because fewer parts are shared? Plus, while its very easy to scale back power its extremely difficult for an OEM to increase it (due to emissions and durability requirements). So instead of having a 455 hp LT1, a 485 hp LT2, and a 515 hp LT3 ... in reality it would probably turn out more like 455, 425, and 395. Since the lower power engines would have to be sold for less than the high output ones, there is another problem: pricing. Either they would have to charge the same for the 455 that they do now & discount everything else (costing themselves revenue) OR charge just as much for the low powered engine as they currently do for the LT1, then ask people to pay thousands extra to get more power. Either way, someone is getting screwed over compared to just offering the best possible engine that they can. Quote:
It helps a bit to throw some hypothetical numbers in here. Lets say it costs 500,000 to make some specific part. That pays for a small team a few weeks to design it, plus the tooling to make it. If you spread that cost over 100,000 units each part needs to cover $5. But now you decide make an alternative, optional part. It will boost sales by 10%, and 20% of the original buyers will opt for this premium option as well. However, it costs another 250,000 to produce (mostly tooling, but some design work as well). So now, you've got $500,000 spread over 80,000 sales ($6.25 per) plus $250,000 spread over 30,000 sales ($8.33 per). On average, it comes to an extra $6.82 per whatchamadealy. Keep in mind that this is on top of whatever the different material costs are, the logistics costs associated with the additional inventory, the reduced productivity that comes from workers needing to make a choice when assembling things, and on and on and on. Of course, the average consumer sees none of that. But for automakers, its all a delicate balancing act. In most cases, some choice is best. In others, lots of choices are. And in yet others, it makes the most sense to offer only a single choice: buy it our way or not at all. And its all done according to how they can get the most profit possible.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
02-17-2016, 05:30 AM | #56 | |
