Old 02-02-2016, 09:42 AM   #43
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
Originally Posted by xgnxs View Post
A standard reminder that you're not just breaking in the engine, you're breaking in the entire vehicle, which includes the transmission and rear end. Look up the break in guides for aftermarket transmissions and rear ends, they will NOT say "install in vehicle, drive hard."
I agree with this statement. I have 2k miles now. I changed my oil at 500 miles. I will do my second oil change shortly to full synthetic amsoil. I changed the diff oil at 1500 miles. I am still driving it somewhat conservatively but I have opened it up and even in break in I went over 80 mph. Although I waited until about 750-1000 miles to see a redline run. Waited until after 1500 to see 150mph. I believe you should take the middle stance. During break in always wait until oil and transmission temperature comes up to operating temperature before you get into it. You can play with it and run it through the rpns. As you get more mileage run up higher by 1k rpm at time. If you do good maintenance and watch oil temperature and not go 100% too soon then you will be fine. Awesome thing about the SS is the heated transmission and rear differential! Although the manual takes some time to get up to temperature and when it does the rear end is up to that temperature as well. Really helps to change the rear gear fluid.
drivingagain is offline   Reply With Quote
Old 02-02-2016, 09:46 AM   #44
stratt
Drives: Waiting on my 2016 Camaro 2SS
Originally Posted by GTIanZ28 View Post
At this point I still say it's slightly notchy and firm. I loved the m6 trans in the old 4th gens. The shifts with the v6 are obvious and I had no issues at all when shifting in anger.
But, on multiple occasions in regular driving I have embarrassingly ground 1st gear. On each occasion I thought I had fully engaged 1st but, it wasn't quite in gear.
I have hope to see further improvement in the shifter feel. It's definitely better than when I first got the car.
I've noticed my sweet spot on my clutch has changed since I got it. It used to be close to the floor, now it's closer to the top. 800 miles now.
stratt is offline   Reply With Quote
Old 02-02-2016, 10:22 AM   #45
drivingagain
Your transmission is different with a different pressure plate and clutch though.
Old 02-02-2016, 10:49 AM   #46
i007spectre
i007spectre's Avatar
Drives: 2016 2SS, 2008 HHR ECTO-2H
I was breaking mine in, but I am at 1600 miles now.
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25
2000 - 9/28
3000 - 9/30
3100 - 10/27
3300 - 10/28
3400 - 10/29 TPW 11/09
3800 - 11/10
4300 - 11/24
4B00 - 11/25
4200 - 12/5
5000 - 12/7
6000 - 12/11
i007spectre is offline   Reply With Quote
Old 02-02-2016, 10:56 AM   #47
stratt
My transmission is different than it was 700 miles ago?
Old 02-02-2016, 11:23 AM   #48
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
THIS!!!! This cannot be stressed enough.
Weather you chance it or not is up to you.
Scarlet: 3/3/16: 2SS Red Hot, M6,
Instagram: @luis_what_it_is
Techn9cian805 is offline   Reply With Quote
Old 02-02-2016, 11:29 AM   #49
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
Originally Posted by chrismarvin View Post
Is it really bad if i'm at like 2500 and still haven't had the oil changed? the dealer told me at 5000 bring it in, I was going to take it in at 3000.
Check your oil life. it's around 30% just do it. You can still flush it at 1500, it won't hurt a thing if you really wanted to.
I am about to hit 1500, 20 more miles except today it's freezing so not driving the camaro. I will replace my filter and keep going till I am about 30% oil life then change the oil with Mobil 1 5w-30 full syn.
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 02-02-2016, 12:00 PM   #50
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
Originally Posted by Drags1998 View Post
The thing that nobody mentions is the fact that You are "Breaking in THE WHOLE CAR"!!!! With newer cars, The oil Tech. and tighter Tolerance's in the engine and the fact that ALL GM pushrod engines now have roller valve lifters. Engine breakin is mostly limited to the piston rings. ALL other parts (pistons,Bearings, Gears, pumps] all run on a cushion of oil. Rings seal within 10 miles. Nuff on the engine. In My opinion the components that requires a careful breakin is the A-8 Transmission and the rear Diff. and the Brakes. Some may not agree and that's OK!!! Everyone will do as they want to, and Hopefully Enjoy EVERY MILE!!!!!!!!!!
Ding, ding, ding. We have a winner!
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 02-03-2016, 06:10 AM   #51
Marine Corps
Drives: 2016 2SS Garnet Red Camaro
I totally agree. I've got 1250 miles on my car and for the most part am following the break-in procedures to the letter. However, my first oil change will be as per normal. I understand that there is no break-in oil used from the factory so I'll have my oil changed when needed. I don't buy into changing oil every 3000 miles. It's just not necessary. I will go with Mobil 1 when I do. To each its own.
Ordered: 8/8/15, 2SS Garnet Red
Built: 10/14/15
Current: Took Delivery, 12/24/15
Added Procharger supercharger.
Marine Corps is offline   Reply With Quote
