#43 |
Retired from Car mfrs....
A few, it is not the valve leaking, it is the droplets inside when you disconnect. If you want to check it, spray it with a degreaser before you attach the cap next time. I have changed the oil using the valve twice, never leaked a drop on my garage floor yet.
#44 | |
![]() Drives: 2016 1LT M6 Join Date: Sep 2016
Through user error, I did spill about a half teaspoon that dribbled down the side of the bag when I was removing the filter. I might either need to make bigger ramps for more clearance (to get a better view of what I'm doing) or go without the creeper next time, so I can slide far enough under the car to see the filter and better position the bag while I'm removing it. Thanks again. |
#45 |
![]() Drives: 2016 Blue 2SS Join Date: Mar 2016
Thanks for this recommendation I just ordered a valve, should make things a ton easier.
#46 |
Just an update, one year later, the valve still working great… I went ahead and put one on my scooter as well, it has a drain plug that is an absolute bitch to get to…
This valve is a godsend when you're in an area where you can't spill a drop, like my condo garage. |
#48 | |
![]() Drives: 2SS - Black Join Date: Oct 2009
#49 |
![]() Drives: 2016 Red Hot 2SS Join Date: May 2016
Is there a difference in these two?
edit: These are same ones, Pennzoil switched to yellow jugs recently. Found this: http://www.pennzoil.com/en_us/latest...w-bottles.html
#50 |
Also, anyone buying pennzoil - don't forget to claim the $2/qt rebate that's going.
http://www.pennzoil.com/en_us/promot...Rpb25hbDE3Lw== |
#51 |
![]() Drives: 17 1SS 1LE Join Date: Aug 2017
Anyone have a torque spec for the bolt?
