#43 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
PLEASE GM, make the 1LE a '17...
#44 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Because the 1LE is a low volume option to increase the track capability of the Camaro. That's what it's been the whole time. Saying the 1LE needs MRC as an option would be like saying the ZL1 needs the V6 as an option. Ford has always made DD capability a priority. That's why the Performance Package isn't as focused as the 1LE.
#45 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
E-diff
Duh |
#46 | |
![]() ![]() Drives: 2017 Camaro 2SS - M6, NPP, MRC Join Date: Jan 2010
I hope the V6 gets some performance package love this time around (not that you care anymore since you're going up to a V8 this time - traitor! ). The SS getting comfortably into the 0-60 3's seems like an absolute eventuality with the previous generation's 3.91 gears, but the V6 is just so darned close to the 4's with 3.27's and run-flat all seasons, I don't see how the engineers at GM aren't straining at the leash to do it.
#47 |
The 1LE is was only $3,500. That's a great deal for a package that completely changed the performance of the SS.
#48 |
![]() Drives: 2001 Camaro SS Join Date: Nov 2009
.... And that is even the understatement of this past decade. Excluding the far more expensive ZL1/Z-28, the 1LE package was nothing short of a miracle transformation for the SS.
2001 Camaro SS- M6 cone killer
#49 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 13' 1LE Join Date: Apr 2012
This new 6th gen is so good that a 1LEcould be: wider wheels/tires, comp shocks and some aero and gearing for 3k and less IMO. Leave the brakes as an option.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
#50 |
I think the 1LE needs to be on par with the GT350 or even TP at the minimum. If the brakes are needed, I feel like they should be included.
#51 |
![]() Drives: Possibly a 1LE in the near future. Join Date: Oct 2012
Yes. The brakes should be included for a truly track capable car. 5th gen 1le guys could easily smoke their oem break setups in a few sessions.
#52 |
Lets not forget the Recaros. I am specifically holding off buying on the whim that the Recaro seats from the future performace models will be optional on SS again. Im a autox junkie, the seats are a tremendous help.
#53 | |
#54 | |
#55 |
Recaros are a must for sure. I would prefer mrc remain an option. The z28 suspension would be ideal.
#56 | |
Use the Force
Walk softly, carry a light saber and drive a ZL1!
