#43 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Current Camaro-less Join Date: Jul 2014
With how aggressive the transmission 1st gear is...a stall might actually *slow* the car down...
Total drivetrain tune? That's gonna be some good stuff. |
#44 |
![]() ![]() ![]() Drives: Want a gen 6 Join Date: Jan 2013
I don't know, if it can get grip with DR's a stall should not hurt as far as I can figure. Also, taller tires could end up lowering the ratio in some cars. A stall may not be a mod I go for, but I could see an argument for it.
#45 |
Some 5th gen 1LEs dynoed right around 400 +- depending on the dyno. Dynos do not mean much unless you compare runs on the same day, same car, same dyno. But still cool to see one of the first.
http://www.camaro5.com/forums/showthread.php?t=429651 Manual 5th gens can be compared to manual Ca6 SSes. So a little more power and a 200 pound loss means about .5 second ET improvement. Most of that comes from the weight loss. The best LS3 5th gen stock run (and a hero run at that) is 12.588. Will we see a CA6 SS manual in the 11s stock? That would be cool. Comparing auto 8s is not a fair comparison for the M6es. They should more easily hit the 11s. We shall see. The CA6 SS is a fast car. Nice to see they no longer fear 5.0s or 392 Mopars. The tables have turned.
#46 | |
Drives: Chevys at the limit Join Date: Nov 2010
![]() Jared Royce 888.308.6007 |
#47 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Way, way faster then that. My '11 GT runs that with a mild converter, tune, muffler swap, basic suspension mods and drag radials. Weighs 4000 pounds with me in it. Those mods on a gen 6, I would say very low 11's...
#48 |
![]() ![]() ![]() ![]() Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
#49 |
They tuned one up here and got 30hp and 40tq gains all the way across.
#50 |
Sales Manager for Chevy
Drives: Tahoe RST Join Date: Mar 2009
#51 |
We live in crazy times people......these American Car Manufacturers are killing everyone right now, especially in terms of bang for your buck! Enjoy it while it lasts haha.
#52 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
A correction factor only exists to give a standard day for your Region, so when you test in the winter or test in the summer you get the same numbers. Superflow has been the go to Dyno testing equipment for all forms or racing for over 30 years and has established STP as correct for the US North America. We Measure Actual numbers with a Torque sensing strain gauge then correct for the Day. Our actual number and corrected number are within 1% on the day I ran the test, I don't consider 1% an inflated number. If anything SAE is overly conservative showing Low numbers compared to Actual measured HP and TQ. STP is backed up by Track results time and time again, I have collected data from this dyno and backed them up at the track for over 13 years now. STP numbers are as REAL world as it gets. Many Dynojets read 10% too high regardless of what correction factor they apply. This is why you see so many high dyno numbers with Low MPH at the track. I am also collecting Air flow data that also backs up our Dyno numbers, 1 lb of air per minute produces 10 crank HP. This car is flowing 46.65 lbs of air per minute, X 10 = 466.5 crank hp. It is also pulling a vacuum above 4000 rpm so a CAI Cold air kit is going to add some power for sure. Anything else I can answer for you feel free. Thank you for asking many people want to know. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#53 |
WFO all the way
Drives: Hyper Blue 2SS, Kalahari, 6 speed Join Date: Aug 2009
My first car was 40 HP..LOL
Awesome power this SS. Did you see the torque with 400 at the wheels from around 2200??? You can pull a tank out of ditch with this sucker!!!
#54 | |
Feels like a Diesel. Ted.
#55 |
Kneel before Zod
Drives: 1998 Silverado & 2013 Focus ST Join Date: Apr 2009
Dat Torque Curve! My body is ready.
...I'll be in my bunk
#56 | |
![]() ![]() ![]() Drives: 2013 Camaro convertible 2SS/RS Join Date: Sep 2014
