Old 06-22-2015, 05:43 PM   #43
Muscle Car Lover
Muscle Car Lover's Avatar
Drives: 2014 2SS M6 "CHRISTINE"
Holy Sh$t!!!!! The TP-LINK TL-WPA4220KIT ADVANCED 300Mbps Universal WiFi Range Extender, Repeater, AV500 Powerline Edition kicks butt!!!
WAY better network ability now! Thanks guys for the help, this is like moving away from dial up all over again.
One weird thing: the lights go out on the units but the signal still seems better. Why do the lights go out?
"But, House Mormont remembers. The North remembers! We know no King but the King of the North whose name is Stark. I don't care if he's a bastard. Ned Stark's blood runs through his veins. He's my king–from this day until his last day."
Mods: ARH headers and hi flow cats, VMAX ported throttle body, CAI air intake, Slowhawk Performance tuning
Muscle Car Lover is offline   Reply With Quote
Old 06-23-2015, 02:41 PM   #44
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
got a question. lets say I have a computer that came with windows 7 64bit. And lets say someone (for gods knows what reason) installed a 32bit windows 7. is it possible to reset the computer to factory settings and put the computer back to 64bit (without the install disk), or will a fresh install be the only way?
Old 06-23-2015, 03:00 PM   #45
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
Since Windows does the check pointing, I have a feeling you're lost from 64 to 32.
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
http://www.camaro5.com/forums/picture.php?albumid=17325&pictureid=134228
sherob is offline   Reply With Quote
Old 06-23-2015, 03:01 PM   #46
45thAnniversary2SS
45thAnniversary2SS's Avatar
Drives: 2012 45th Anniversary 2SS LS3
You will need to backup your data and reinstall. How many GB of RAM does your machine have? Start Menu -> Computer (right click and select properties).
45thAnniversary2SS is offline   Reply With Quote
Old 06-23-2015, 03:04 PM   #47
sherob
sherob's Avatar
Probably a flaky box. You might want to return it, in case this is just the beginning of problems.
Old 06-23-2015, 03:59 PM   #48
PoorMansCamaro
Drives: Really Slow
6gb
edit: and I don't have the 64bit windows 7 boot disc anymore. I'm going to go get a 64bit windows 8
Sent from my iPad using Tapatalk
Old 06-23-2015, 06:48 PM   #49
PoorMansCamaro
Drives: Really Slow
weeeeeell......looks like I was wrong, my computer was never 64 bit compatible.
So next question, does anyone know if I can change out the cpu to one that's 64 bit? I have a Dell XPS 8100. I believe I currently have the i7, but not sure which one.
and looking further into it, it seems all the i7 processors that are available for the xps 8100 are 64 bit. i'm so confused.
Here are the specs between the two:
http://www.cpu-world.com/Compare/338...i7_i7-870.html
and here is a pdf of the processors available for the xps 8100.
http://downloads.dell.com/Manuals/al...uide_en-us.pdf
although I can't find anything about the i7 750. I think it's a typo and should be i5 750, which is also 64 bit, I believe.
Old 06-23-2015, 06:51 PM   #50
PoorMansCamaro
Drives: Really Slow
looking further on that pdf, there is a L3 cache (not sure what that means) and lists i7 750 with up to 6MB of RAM. which is how much I have. so that has to be the one I have, but can't find any info on it. But everything seems to be 64 bit. I got a 64 bit windows 8, but it won't load.
edit: windows 8 32 bit installed fine.
Old 06-23-2015, 08:00 PM   #51
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
WELL, in typical computer geek fashion, a casual mention of being geeky has turned into a tech help thread.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 06-23-2015, 08:19 PM   #52
PoorMansCamaro
Drives: Really Slow
to be fair, the OP said troubleshooting issues.
Old 06-23-2015, 08:24 PM   #53
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Have you tired turning it on and off again? That usually helps
In a more serious fashion, if you want to verify the proc in your computer you should be able to see it in the system page of the control panel on Windows 8. If that fails, download CPU-Z. It will give you all the information you need to know for free.
Old 06-23-2015, 08:29 PM   #54
PoorMansCamaro
Drives: Really Slow
ok, i'll try the cpu-z thing. I checked in the system page. only gave the current OS. I will also check all the updates for all drivers, BIOS, etc, if they are any different than a 32bit OS.
Old 06-23-2015, 08:32 PM   #55
menendez1293
Drivers shouldn't help at all with loading the 64bit OS. If your computer came with 6GB of ram, then it is hard to believe that it shipped with a 32 bit OS. The max a 32 Bit OS can support of Ram is ~4GB.
Here is what CPU-Z looks like on my computer so you get an idea.
Old 06-23-2015, 08:35 PM   #56
PoorMansCamaro
Drives: Really Slow
Attachment 725741
ok thanks.
yeah, it's weird, because it says I have 6GB of ram. I'll do more digging when I get off work.
