Old 06-10-2013, 12:42 PM   #43
Jason P
Jason P's Avatar
Drives: 2011 2ss
2002 dodge everything works perfectly.
2011 2ss Ram twin plate ceramic clutch, Texas speed 418 LS3 235 /243 .621 / .624 cam, ported and polished heads with dual springs,magnum push rods, Hotchkis race pack, Stainless Power long tube headers with no cats, Magna Flo competition exhaust, lpe fuel pump, magnuson supercharger with overdrive and port matched blower plate, IW 8 rib pullies, AEM meth kit, id 850 injectors, 3 bar map, halltech cai, zl1 rear diff
Jason P is offline   Reply With Quote
Old 06-10-2013, 12:43 PM   #44
Arachnyd
Master of all trades
Arachnyd's Avatar
Drives: 2many2count
I had so many issues with my last Ford and Chevy Trucks I swore I'd never gone back. My last three have been Dodges and I LOVE them. Hard pressed to buy anything else... Have had less problems with all three combined than I had with any one Chevy or Ford (and that includes my camaro! haha)
2010 Camaro SS modified extensively. I stretched the body to make it a 4 door, but I swapped in the 3.6L DI V6 for fuel economy. Then I picked up a corvette body around the V8. I also swapped the body for a C2 Z28. (In short I traded it for three cars, a Corvette Z06r, a C2 Camaro Z28, and a Cadillac CTS Summer Performance package 3.6L DI with Aisin 6spd.)
Arachnyd is offline   Reply With Quote
Old 06-10-2013, 06:19 PM   #45
bluBlud
bluBlud's Avatar
Drives: 2013 2SS/RS/1LE
I've got an '06 Ram 1500, 52k miles. I've been very happy with it until recently. Overall, it seems like they're cheaper to buy but more expensive to maintain. For example, they have copper tipped plugs that are supposed to be changed every 30k miles whereas most run much longer. I had to put $2000 into it last year for bearings and hubs, tie-rod ends, fluids, and a other odds/ends. I don't offroad or plow so I was surprised the front end wasn't more durable. Now, I'm looking at another $1-2k to pull the dash to replace parts of the vent system. I've had friends with F150s and Silverados, they've had their share of problems too but I don't remember them complaining about the sme series of spendy repairs like I'm seeing now.
bluBlud is offline   Reply With Quote
Old 06-10-2013, 06:37 PM   #46
trainman
Drives: 2012 CTS V,2000 Firehawk, SRT Ram
I've had my 2004 SRT-10 Ram since it was new, 9 + years, 66,000 + miles, 300+ drag races, replaced a couple of clutches, one set of spider gears, but the engine does not use oil between changes, I have never had the valve covers off, pure stock internally, NA and has run a best of 11.63 @ 118. Love the truck...even though I am a GM man first (2000 Firehawk, 2012 CTS V coupe, 73 SD 455 Formula, 1964 GTO) this truck has been a blast and I am now to a point where we may rebuild the engine with heads and cam just to explore the limits of an NA 4100 lb truck, that is fully streetable....stay tuned for more this fall. Here's a video against a new Z06 (LS7, drag radials)....he called me out...and a second video against a Kenne Bell equipped Lightning....enjoy.
http://api.viglink.com/api/click?for...13709075083858
http://api.viglink.com/api/click?for...13709075673088
trainman is offline   Reply With Quote
Old 06-10-2013, 07:36 PM   #47
motorhead
09 and up dodge trucks are very good. The earlier ones aren't bad, but they do like to go through ball joints and wheel bearings.
Old 06-10-2013, 08:08 PM   #48
turboguy327
Drives: 2011 Chevy Camaro
09 and up dodge trucks are very good. The earlier ones are bad, but they do like to go through ball joints and wheel bearings.
How do you make this crap up?? Seriously. Stop spreading completely incorrect information. It's incredibly annoying and makes you look really dumb. Did you just think of random parts and make that claim up??
turboguy327 is offline   Reply With Quote
Old 06-10-2013, 08:25 PM   #49
motorhead
Piss off. I'm a huge dodge fan and have own several 04 to 07 2500 4x4s in my business and my buddy currently owns an 06. I'm telling this based on my own experiences with many of these trucks. Sorry that the truth upsets you so much.
Edit: I see what happen that may have caused your aggression. I missed the "n't" in my post.
Old 06-10-2013, 08:32 PM   #50
turboguy327
Same here. I've had over 10 since the 03 change and have yet to change a ball joint or wheel bearing. A ujoint here and there but that's due to inexperienced plow drivers that don't stop the truck before shifting directions mostly. Your trucks may be overloaded if your going through stuff like that more than you should. Not a fault of the truck.
Old 06-10-2013, 08:35 PM   #51
shank0668
shank0668's Avatar
Drives: '14 LML/'06 LJ/'76 Trans Am
Still have the Formula SD-455?
shank0668 is offline   Reply With Quote
Old 06-10-2013, 08:37 PM   #52
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
Originally Posted by mikeyg36 View Post
Beg to differ. If the car was built when Chrysler was under Daimler, then it's crap.
if it is a HEMI motor (5.7L) then it is probably pretty solid, even when Daimler owned them.
if it was the magnum motors 4.7L or 5.9L then yes pure crap.
however the biggest issues aren't the motors, it is the hybrid canbus electrical systems borrowed from MBZ and cross-bred with existing Chrysler LLC technology. some MBZ parts, some Chrysler, some left over $hit in parts bins from past years models that were mixed and matched. Early 1/2 year model builds with different parts than the later 1/2 year that aren't compatible, etc.
I'm only responsible for what I say, not for what you fail to understand.
Mr. iNCREDIBLE is offline   Reply With Quote
Old 06-10-2013, 08:38 PM   #53
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
Love my 2013 Dodge Ram 1500 4x4 Crew Cab Laramie w/Hemi
THIS BY FAR, ISNT JUNK!!! The Uconnect puts My link to shame! Plus the stock system in my ram put the BA System in my ZL1 to shame! IMO These are very nice trucks! Go test drive one .
kevin1106 is offline   Reply With Quote
Old 06-10-2013, 08:42 PM   #54
motorhead
All I can say about overloading is that all of my Chevys are equipped exactly like the Dodges were and they never wear out these parts. I am considering a new 2500 or 3500 dodge to see if they improved. I have many friends and family members that have 09 and up 1500s, and they are very reliable along with being very nice trucks. I just have no use for a 1/2 truck. Like I said I'm only telling based off my experiences along with my buddy which doesn't load his hardly ever.
Old 06-10-2013, 08:48 PM   #55
mikeyg36
Drives: 2015 Z/28 #533
Nice truck Kevin. The new ones are great.
mikeyg36 is offline   Reply With Quote
Old 06-10-2013, 08:49 PM   #56
mikeyg36
The Hemi motors are good, but they can't hold a candle to the LS engines.
