12-28-2012, 05:27 AM | #43 | |
having FUN now 13.66@101
12-28-2012, 10:57 AM | #44 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
In our case, its probably on the low end, and so losing 57lbs of unsprung weight is probably more like 2 - 4 times that amount in sprung weight, so 100 - 200 lbs I'd guess. Even so, that is a FANTASTIC weight loss to unsprung weight. I'd be extremely happy.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
12-29-2012, 08:34 PM | #45 |
dropping the steelies is one of my favorite mods lol, looks so much better and the 44 lbs i dropped made a big difference in driving feel. car feels more nimble and spins the tires easier now.
12-29-2012, 09:21 PM | #46 |
Drives: 2011 LS Join Date: Oct 2010
Amen! Also KMP post on weight is a great post to show how weight affects on dyno. Also overall tire diameter as stated in poor man gear change will add as well. This may have been already stated but I got behind on this thread and didn't read all.
12-30-2012, 11:04 PM | #47 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
rs headlights weigh 10lbs each
Email: rdurso1@yahoo.com |
01-01-2013, 09:20 PM | #48 |
weighed and took out the washer fluid resivor today it weighed 12lbs filled!
01-08-2013, 10:27 PM | #49 | |
Drives: 2010 Chevy Camaro 2LT / RS / Auto Join Date: Jan 2010
To be able to calculate the equivalent chassis weight of a specific value of Rotational Mass, you will need to compute the following:
40 lbs of (Wheel/Tire saving) = 255 lbs of chassis weight Camaro V8 2SS (3935 lbs) (0-60mph: 4.7s) 40 lbs of (Wheel/Tire saving) = 233 lbs of chassis weight Hope this helps |
01-14-2013, 04:02 PM | #50 |
Track > 1/4 Mile
Updated.
01-26-2013, 03:08 AM | #51 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
Nobody knows the weight of the v6 rotors?
01-26-2013, 09:02 AM | #52 |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
I wish someone did, because I am trying to find some light weight drilled/slotted rotors or depending how how drastic the weight diff is between the ss brake system, upgrading.
01-26-2013, 09:53 AM | #53 | |
The forum search button is our FRIEND. Type in rotor weight. two finds come up http://www.camaro5.com/forums/showth...t=rotor+weight See post 2 and 3 for SS rear rotor weight and V6 rear rotor weight. SS is 24 lbs. V6 is 17.3 lbs. See post 5 for front rotor weight for both. SS front rotor: 25.2 lbs. V-6 front rotor: 22.0 lbs. Hope this helps you guys out.
01-26-2013, 10:15 AM | #54 | |
COTW 9/16/13
01-26-2013, 10:21 AM | #55 | |
Let us know what you come accross, rotors and pads are on my list to replace in the next 12 months. especially if lighter.
01-26-2013, 10:27 AM | #56 |
COTW 9/16/13
Same here, and will do
Tags |
light weight, weight loss, weight reduction |
