#43 | |
General Motors Aficionado
Drives: 2023 GMC Canyon, 2023 Expedition Join Date: Aug 2008
1. Leaving home with a fully charged battery pack provides 40 or so miles of driving range with the engine and generator inoperative. The 149-hp permanent-magnet AC motor draws electricity from the 16kWh battery pack to drive the front wheels through a 7.0:1 speed reducer/torque multiplier. 2. Like any energy-conversion device, electric motors are more efficient at certain operating speeds. When the Volt exceeds fifty mph, a clutch holding the planetary gear set's ring gear is released. A second clutch engages to connect that ring gear to the smaller of the two electric motors. Now both electric motors draw electricity from the battery pack and the effective drive ratio shifts to 2.16:1. Top speed is governed at 100mph. 3. When the Volt's battery is depleted to a 30-percent or so state of charge, the gasoline engine is automatically started to give the battery a rest. The clutch connecting the gasoline engine to the smaller electric machine closes so that this device, now acting as a generator, can provide electricity to the main electric-drive motor. Another clutch holds the ring gear fixed, yielding a 7.0:1 overall drive ratio between the motor and the half shafts powering the Volt's front wheels. This regime is used for speeds below 30 mph. 4. At higher cruising speeds, the planetary ring gear is again released, shifting the AC motor drive ratio to 2.16:1. The engine continues providing the power to spin the generator which in turn supplies the drive motor with electric current. In addition, the engine supplies torque to the planetary ring gear through the smaller electric machine. (This is the engine driving-the-wheels scenario heretofore denied by GM.) Operating in this regime, the Volt is both a series hybrid and a parallel hybrid. I expect Edmunds and Jalopnik to issue retractions.
2023 GMC Canyon Elevation 2023 Ford Expedition SSV (State-Issued) |
#44 | |
... ![]() So, what I take from this is that the Volt acts as an EV until a situation arises where it responds by acting as a hybrid; seems to me that this is simply trying to negate a disadvantage of an EV by adding this hybrid safeguard. |
#45 |
I used to be Dragoneye...
A concept that's been the core of the program: An EV without the anxiety.
#46 | |
People are making a mountain out of a molehill with this. It's a total non-issue and in fact improves the performance of the Volt. There are just people out there who don't want to see GM succeed.
#47 | |
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2008
#48 |
What kills me is people are pissed off about this "lie" that is actually a good feature of a well thought out design. Who cares what it's called! These vehicles are in a time like the SUV's of the late 90's early 2000's they weren't trucks they weren't cars and we still make up new names for them rather than call them wagons. The Volt will be a great product I'm sure but some people are gonna piss all over it because it's GM's product. I hope it comes out swinging and proves them all wrong.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
#49 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: fanboys and ass kissers crazy. Join Date: May 2008
I still think the Volt is a wonderful vehicle but please call a spade, a spade....it's a Hybrid
"BBOMG - More than just a car show.... It's an experience!"
#50 | |
#51 |
Here's a link to GM's website:
http://media.gm.com/content/media/us.../Oct/1011_volt The heart of the matter is how you translate this paragraph: "There is no direct mechanical connection (fixed gear ratio) between the Volt’s extended-range 1.4L engine and the drive wheels. In extended-range driving, the engine generates power that is fed through the drive unit and is balanced by the generator and traction motor. The resulting power flow provides a 10 to 15 percent improvement in highway fuel economy. " That's like saying there is no direct mechanical connection (fixed gear ratio) in any GM vehicle with an automatic transmission. True statement isn't it?
#52 |
The way I understand it is that the ICE generates electricity directly to the second electric motor which works in conjunction with the larger electric motor. The second electric motor is like an overdrive gear.
This is all such a huge cluster****. The only people who really know what goes on when a Volt starts moving are the engineers, and they probably can't explain it in terms that everyone will understand.
#53 |
Blessed
Drives: 2013 Sonic RS MT Join Date: Dec 2007
sorry for being simplistic.
but I see two issues here. One: the car is never mechanically powered. Electrically powered motors always "drive" the rear wheels. the caveat is that under low batter power and heavier load, the ICE helps to create the electricity that drives the car. Not to say that it mechanically drives the car. FWIW.. I really don't care how one might interpret this, but to me it is is what it is. Call it whatever you want but don't confuse the capability. Two: As with any headline news, there is always a slant. it's a shame but its true. The good news here is Camaro5 is full of members who can do their own research and come to their own conclusions.
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
#54 |
The bottom line is that without electricity, the Volt doesn't run. Simple as that. If you ripped out the electric motors and battery and tried to drive the car, it wouldn't run off the gasoline generator.
#55 |
Moderator.ca
Here is a graphic Motor Trend showing how it all works together:
![]() http://www.motortrend.com/features/e...cks/index.html As I think through this, I can see exactly why it was done. GM very carefully worded their press release about this, again with the goal of misleading us. There is a mechanical link between the engine and wheels: engine -> generator -> planetary gearset -> wheels. It is not a direct link as the generator is stuck in there compared to how a car normally opperates. But there has to be a mechanical link because of regenerative braking. With regen, the most logical setup would be to have the wheels driving the generator. Well, if you have wheels->planetary->generator and engine->generator ... you've got a mechanical pathway from the engine to the wheels. Now, at some point they realized the potential use of this and figured out a way to implement 'partial mechanical' driving mode to boost efficiency. From an engineering perspective, its all very clever and they should be applauded for it. But it also goes against what we've been led to believe about the Volt, particularly since they started calling it an EV. I can't believe that the engineers were doing this while their PR and media people had no clue. GM has to be more competent than that. But you could also drive it without ever plugging it in.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#56 |
and just to add to DG's comments above, we both think GM's Volt is technically far, far superior to anything else out there.
| Thread | Thread Starter | Forum | Replies | Last Post |
| Shno's House of Z | Number 3 | Camaro Z/28 Forum - Z/28 Specific Topics | 17976 | 12-27-2021 12:07 PM |
| PWA "The Lounge" | DGthe3 | Off-topic Discussions | 143773 | 11-06-2010 11:00 AM |
| Would you buy an electric car? | PAUL SS | General Automotive + Other Cars Discussion | 32 | 05-11-2010 07:27 AM |
| GM Reveals Chevrolet Volt MPV5 Concept | FenwickHockey65 | General Automotive + Other Cars Discussion | 33 | 04-27-2010 05:33 AM |
| Chevrolet Volt | Urthman | General Automotive + Other Cars Discussion | 160 | 09-29-2008 08:17 PM |
