03-07-2017, 02:38 PM | #43 | |
Drives: 16 Camaro Join Date: Jan 2016
If this is such a big deal to you I'm surprised you ever take your car to the dealership and allow them to change your oil. If you can't trust them with this don't let them change it. I can't believe you would fire someone for a mistake like that. I hope you are never in a position where you make a mistake and your manager has the same salt you have for this person and fires you. |
03-07-2017, 03:29 PM | #44 |
Drives: 2008 corvette Join Date: Jun 2016
my free oil change was done and the next one I did myself. I only had 7 quarts total. the dealership just doesn't know
03-07-2017, 03:37 PM | #45 | |
Drives: 2004 Corvette Join Date: Jan 2016
03-07-2017, 04:08 PM | #46 |
FASTER!
Drives: Challenger Hellcat, 2SS Camaro Join Date: Apr 2008
Sorry to say I'm in a senior leadership position and I expect accuracy from my employees. My leadership expects the same from me, but then I'm in a profession where mistakes aren't well tolerated as they are typically very costly.
Yes I fully understand engines, how they work, down to the oil pickup. Go ahead and only fill your car with 8.5 quarts of oil and have a ball. Lemme know how that turns out for you Some of the rest of you guys could use a course in reading comprehension LOL |
03-07-2017, 06:47 PM | #47 | |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
Firing someone every time a mistake was made would be insane. Mistakes happen.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
03-07-2017, 07:11 PM | #48 |
FASTER!
It's not a mistake, it's negligence, checking the oil dipstick is SOP at this dealership and this tech ignored it. You guys half ass your jobs to eh?
03-07-2017, 07:17 PM | #49 | |
I used to be Dragoneye...
If this guy was new...and first time mistake sort of deal? Ok, fine...get a talking to. But if I were that person's manager, and I had to drive out to your house to fill up oil, in an effort to retain your business because this tech made a repeated mistake like this - I would, in fact, fire him/her. Been through situations like this (on the management side) several times. Starts with a discussion. Continues with coaching...starts to decline with restatement and a "final" sort of warning...then, termination. Gotta have pride in what you do and how you do it. Whatever you do. If you don't...why are you doing it? Still....*moderator hat on*.....let's play nice, gentlemen. |
03-07-2017, 08:16 PM | #50 | |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
03-07-2017, 09:17 PM | #51 | |
Drives: 2013 ZL1 Join Date: Nov 2015
What profession is it that doesn't make mistakes, It sure isnt NASA, or our government, or Defense industry. Now that I think about, I don't remember ever meeting a human that didn't make mistakes on a daily basis. I have meet a few that denied making mistakes, but none that were as perfect as they thought they were. |
03-07-2017, 11:27 PM | #52 | |
I've worked at a dealership before, these types of customers are not the norm. Life is too short, if the tech is any decent, the manager probably just told the tech "hey, heads up when doing an oil change... but don't worry about it. People like that aren't worth it."
03-08-2017, 07:45 AM | #53 | |
FASTER!
Back to the point at hand..... Mr. slacker oil change tech probably does 12 oil changes a day. I'd say each one takes 30 minutes and technically that would be 16 a day, but he's a slacker as we've already established, so let's call it 12. They use a dispenser system at this dealer to put the oil in the sump, which is pretty common. They're not pouring the oil in from containers. The SM mentioned this as a big risk when we chatted as the dispenser system can get off on calibration and not dispense the commanded amount of oil. We see this in my example as the paperwork showed 9.0 qts dispensed, but I only got 8.5. 1/2 a quart isn't terrible but it would be on the edge of what I'd be OK with as a SM and would want it something less than that. Now let's discuss what would happen if that dispenser got way off. Now it's only dispensing 2.5 quarts. Mr. slacker oil change tech performs 12 oil changes and summarily burns up 12 engines in the process as the improper amount of oil was dispensed AND he didn't catch the issue as he was not checking the dip stick as he was trained. Pretty expensive day for the service department, and I'd wager more folks than just Mr. slacker tech would lose their jobs. I also gotta wonder if I come back in 6 months and post a similar thread, only instead of referencing my Camaro, I instead reference my Dodge Challenger. I wonder if all these "oh it's no big deal" responses would be the same, or would it be dog pile on the idiots at Dodge LOL. Would be an interesting experiment and would be telling for the character of information one could reasonably expect from this forum. OH, and Mr. slacker oil change tech also did not reset the oil change monitor in the car. That was the first indication I saw of potential problems on the drive home. |
03-08-2017, 08:01 AM | #54 | |
Drives: 2016 2SS Join Date: Aug 2016
Not to go off topic but I guess I will..... I don't believe this is how the recall is worded. I believe its a build date issue on the line. If it was built before (or after) a certain date it gets replaced regardless. Mine had zero contact and was replaced because the date fell into the failure zone |
03-08-2017, 08:10 AM | #55 | |
Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
While I always put the correct amount of oil in, it's not like a few thousand miles later I've never noticed that it's a quart low (like my Tahoe, which takes far less than 10 quarts, so a higher percentage of oil missing) and the oil pressure gauge never showed a drop in pressure. I also didn't immediately sell the thing and it had driven with -1 qt for longer than 15 miles. Everyone understands your frustration and you have every right to be. But you're making mountains out of mole hills. |
03-08-2017, 08:15 AM | #56 | |
The tech leaving the oil level low and not checking when finished is unacceptable. Solution , add oil, remind tech to check oil level before delivering vehicle. No need to burn the dealership and kill all the employees. |
