10-21-2016, 12:20 AM | #43 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
You ignored my comment on brake pad material. This makes a difference... Listen, the 1LE is a bad ass car. GM did a fantastic job. VERY capable. AWESOME value! I'm just not a proponent of dogging a car's performance, like with that of the GT350's braking, until you really consider what you're dealing with. Stock for stock, yeah, it got beat 60-0mph. But, around a track, lap after lap, the 1LE will fade before the GT350, stock for stock (there are comments from Randy hinting on this, but, hey, put in some good brake fluid and the story changes). Put some different pads in the GT350, maybe the 60-0 story would be different. That's all im saying. |
10-21-2016, 12:28 AM | #44 |
Maybe it's not pads. Maybe I'm wrong. Maybe its the GT350 has shit anti-dive. Just given the brake equipment, the GT350 shouldn't be worse
10-21-2016, 06:15 AM | #45 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
...just because a car has "bigger and better equipment" doesn't mean it will functionality always be superior. There are plenty of factors that can come into play. Heck, balance under heavy braking alone is huge, initial bite, etc, etc. Bottom line is the SS 1LE has shown it's braking talents in both the MT and CD track tests... |
10-21-2016, 08:13 AM | #46 |
Drives: 17 SS 1LE Join Date: Dec 2015
Maybe the GT350 has heavier wheels
10-21-2016, 08:14 AM | #47 |
マスタング = 遅い
10-21-2016, 09:24 AM | #48 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - Last edited by hotlap; 10-21-2016 at 12:11 PM. |
10-21-2016, 11:51 AM | #49 | |
What's the link to that C/D test? I'm asking because the weight they have posted in that graphic you attached says, "3452" for weight... that would be the LT weight. |
10-21-2016, 12:17 PM | #50 | |
The SS brakes better though with smaller diameter discs and 4-piston calipers. Its interesting that reviewers always say the SS brakes feel softer even though it performs better.
http://www.caranddriver.com/comparis...e-specs-page-4
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
10-23-2016, 11:26 AM | #51 | |
Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
From a hardware standpoint, the Camaro is significantly superior to the Mustang, it's not even close. It's just a better car. No one would have thought the 1le would outperform the much more expensive, more powerful gt350. But it does. |
10-23-2016, 01:42 PM | #52 | |
Drives: Poop Join Date: Aug 2016
Unless of corse you are taking about the GT, where the SS holds no significant advantage. The GT really a tune away from the SS 1/4 mile. Better tires, yes. Small weight advantage, yes. Small horsepower advantage, yes. Those things are relatively cheaply overcome with the aftermarket. I don't really saw anything that would be considered "significant" though. |
10-23-2016, 03:09 PM | #53 | |
Drives: E92 BMW M3 Join Date: Oct 2012
I think a lot of the gaps will be closed in 2018 by additional factory option for the refresh, but we will have to see.
J-Rod Built and Matt@FSP Tuned |
10-23-2016, 06:12 PM | #54 | |
The exhaust and MT-82 are by no means detrimental to performance. Really, as far as performance goes it nealrly all in the weight, horsepower and tires. It all ads up, but the significant difference is greatly overplayed, and negated by a tune a wheel/tire swap. |
10-23-2016, 06:29 PM | #55 | |
マスタング = 遅い
10-23-2016, 06:46 PM | #56 | |
That's not to say it's perfect, you obviously got a lemon. |
