09-02-2016, 09:51 PM | #43 | |
Drives: 2016 Camaro 2SS ... 2024 Camaro 2SS Join Date: Aug 2016
but for my A8 V8 it has the liited slip .. LOL and I don't know what to do......would it cost more than a regular oil change?? i'll change it too at the same time as my oil...... unless the fluid in there is using stronger break in fluid as well |
09-03-2016, 12:44 PM | #44 |
Drives: 2017 1LE SS Join Date: May 2014
After my break in period and right before I went to track, as per the manual I changed the rear end oil. I *think* there might be a TSB on rear end oil for some also FYI... Any way, I changed mine.. Car ran quieter and smoother on roads after that. It was 150.00 to change.
'If one day the speed kills me, don't cry. Because I was smiling.' - Paul Walker
09-14-2016, 05:39 AM | #45 |
Drives: 2010 Chevy Camaro 2LT / RS / Auto Join Date: Jan 2010
So you guys suggest to change the Rear End oil at 1500 miles even though no noises are heard ?
09-14-2016, 06:10 AM | #46 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
09-20-2016, 09:31 AM | #47 | |
Drives: 2016 Chevy Camaro 3.6L V6 RS Join Date: Aug 2016
2016 Chevrolet Camaro 2LT 3.6L V6 - Summit White
09-20-2016, 09:34 AM | #48 |
On Sale for 22.99.
11-15-2016, 01:49 PM | #49 |
Drives: 2016 RED 2SS BAD ASS AUTO 8 Join Date: Aug 2016
GM Guy
I remember reading on breaking in the new engine before you stomp on it and a GM Engine builder replied that they actually run and test the engines before they install and the oil is changed at that time. If it was need to change at 500 miles it would be in the manual...you guys need to get over the old wives tales about changing oil...that may have been needed 50 years ago but not now...nobody building cars today requires a break in oil change
11-15-2016, 03:25 PM | #50 |
I changed my SS oil around 6500 miles, 10 percent oil life and seems to be doing fine. I used 10 quarts of Valvoline Synthetic 5W30 and a Mobil 1 #113 oil filter. Yes the LT1s do hold 10 quarts. I'm in agreement with some posters that the oil doesn't need to be changed early unless a person has the money and or desire to change it. Just go by the oil monitor and by all means check the level frequently during the break in miles. I had to add a quart to mine around 2500 miles and didn't have to add anymore until I changed it for the first time.
12-07-2016, 11:02 AM | #51 |
Software Architect
Drives: 2017 Camaro 2.0L Turbo Join Date: Nov 2016
what kind of oil and oil filter combo do you guys recommend?
12-07-2016, 11:45 AM | #52 |
Drives: 2017 camaro SS blue w/white stripes Join Date: Nov 2016
GM will not pay for your 2 oil changes until its to 20%, its total bullshit. I paid for them they are mine to use when ever I feel like it. But no GM will not pay for it until its to 20% of the oil life... That shit pisses me off!
12-07-2016, 12:11 PM | #53 |
Retired from Car mfrs....
This is not true, your dealer is making that call....my dealer will do them anytime, and many others are the same.....
12-07-2016, 12:18 PM | #54 | |
Drives: Challenger SP Shaker/Arcadia Denali Join Date: Jan 2016
12-08-2016, 07:03 AM | #55 |
Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
Depends on the dealership... Took my Colorado in for a freebie with only 1500km on the odo; got some weird looks, but whatever
12-08-2016, 08:12 AM | #56 | |||
I used to be Dragoneye...
The engines go through a "dry" run...where they simulate pressures without fuel for 2 minutes or so. It is true that they fill them with oil at the plant, and each engine goes through this test. However, that is not "break in". The car is also test run on a dyno at the end of the assembly line for a few minutes to check that all systems are working. This is not "break in", either. You are probably right that engines do not need such early oil changes. Tolerances are much tighter than they used to be. Not as much wearing in being done in those first 1500 miles. But keep in mind...the 1500mi break-in period is not just for the engine. It's for every moving, temperature-changing component... Also, I forget the exact details, but the Corvette team indicated that an early oil change may be necessary for Z06s, since a seal somewhere may cause foaming in the oil as it ages/heat cycles. So their still is wear, and reasons to do an early oil change...it's certainly not going to hurt. And what does it cost...$80 to do it yourself? Maybe less? Quote:
I used my complimentary oil changes at 500, 1500, 8000, and 18,000 (I think...the last two were dictated by the oil life monitor) |
