02-29-2016, 04:43 PM | #43 |
Drives: Car Join Date: Jun 2010
I have that sticker... C70 is listed along with S0O. I have the color shifting lighting on the doors, cup holder and around the MyLink screen and I can set them to follow the driving mode, go to show mode while not moving, or my choice from the preset color grids.
That's why I was confused. It was my understanding it was installed before I picked it up and that it flowed with the ABL. But, since it's so new and there's so few with it from the factory, I wanted to ask for those that actually have it and what it's supposed to look like from under the footwell and while it's in proper operation. |
02-29-2016, 05:16 PM | #44 | |
Drives: 2016 Camaro 2SS Join Date: Feb 2016
02-29-2016, 05:20 PM | #45 | |
03-04-2016, 10:29 AM | #46 |
Drives: Waiting on my Hyper '16 Join Date: Jul 2011
has anybody found out where to tap into the dome/map lights yet?
1978z28 Original paint 355 solid roller 4 speed
2016 Hyper Blue 1LT RS package with all the goodies Sold 6/20 12/10/21 bought a Silver Ice 2SS 6 speed with 40k |
03-20-2016, 08:39 AM | #47 | |
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP Join Date: Jan 2016
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates. Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges Order ID: TDHQMS 1100 on 01/07/2016 at Penske Chevrolet 6000 on 02/23/2016 Delivered to customer |
03-20-2016, 08:51 AM | #48 | |
Nightfall Gray Blackout
Drives: 2016 Camaro 2SS Join Date: May 2012
03-20-2016, 09:06 AM | #49 |
On the 7" kit it comes with a control switch because it can not be ran by the radio but on the 8" kit you do not get the control switch because after installed and the system reprogrammed you can control the lighting like it came from the factory by the radio.
03-20-2016, 10:42 AM | #50 |
Here is the 3 radio options.
11-14-2016, 12:27 PM | #51 | |
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
11-14-2016, 01:12 PM | #52 | |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
Particularly, the part number to any door retention clips that are to be replaced rather than re-used. I am building my own "spectrum" kit and fabbing up my own door swoosh lights like how you bought and want to make sure i have everything i need once i remove the door to put it back together. As far as my footwell lights. They are not from gen5diy. They are tubes and they do stand out a bit wherever you mount them (probably about half an inch or so). I have them mounted far enough back in the footwells and off to the sides that you would literally have to have your head on the floor to see them. I have a couple under the front seats too near the rear so that they light up the rear footwells as well. I may be replacing these with my new "spectrum" system though. |
11-14-2016, 06:01 PM | #53 | |
01-29-2017, 03:38 PM | #54 |
Does anyone know where I can get the "Light" that goes around the radio? I have a 1SS and it doesn't change color, want to change it to Red.
01-29-2017, 04:27 PM | #55 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
The easiest way for you would be to take apart the radio and remove the White leds. Then solder in some reds. Just reinstall and you're all done. I've included a pic of the white led that would need to be replaced. You would need 2 for both sides of the radio.
04-25-2017, 09:37 AM | #56 |
Drives: 1LT 2.0T A8 Join Date: Jan 2017
I have a 7in display so is the control switch for the 7in display footwell lighting or do I have to purchase the spectrum lighting first in order to have footwell lighting. My dealer told me that there was only one part number for the footwell lighting and that all models would take the same one. Are there 2 different part numbers for the 7in and 8in? I don't want to purchase the spectrum kit I only want the footwell lighting.
