03-05-2021, 02:16 AM | #43 |
GM wont sell you a car with a warranty if its not built to handle it. You need brakes, suspension, fuel system, tires, and drivetrain. look at my sig. i got close to $65 in my 2SS with no supercharger. No labor. I do my own. i should have just bought a ZL1. im just going to keep it stock i said.
03-05-2021, 05:51 AM | #44 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
And expect to pay for new tires more with a S/C. I know my stock tires could never handle adding F/I on my LT1.
03-05-2021, 05:53 AM | #45 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Does anyone own a Callaway Camaro? Was just curious. I was watching some videos on youtube. I'm sure you can get high HP & Torq for the same cash aftermarket, but interesting you can get the Callaway setup and full warranty.
03-05-2021, 06:55 AM | #46 |
And you would need to add a wider set of rear wheels plus tires to help handle the increase in hp with a supercharger like a ZL1 has.
03-05-2021, 08:02 AM | #47 | |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
03-05-2021, 10:26 AM | #48 |
Black lightning
Exactly the lt1 can get that around 20.000
[ 2021 Camaro ZLE 10 speed
03-05-2021, 09:32 PM | #49 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
With how sketch the bottom end is with piston ring gap and all that on the LT1, hard pass on all that. What I'd rather see is a more overt option from GM to have cars setup with their heads/cam package as an actual model (for non-CARB locations).
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
03-06-2021, 01:55 AM | #50 | |
Drives: 2016 Camaro 2SS Join Date: Sep 2020
let's say your car is totaled and it's damaged. Do you lose the 7k invested in it? Or lets say car is stolen and not recovered. Your auto insurance isn't going to cover an expensive add on. That is why I'm always hesitant on it. What happens if the car is stolen or wrecked? I'd rather just get a Zl1 or Hellcat and have it already on there and just add some minor mods after to the car. |
03-06-2021, 02:59 AM | #51 | |
Drives: 2018 Camaro SS Join Date: Jan 2021
They will raise what they give you to the value that it would have on the car to make you whole. Will not get full 7k unless you add to policy. Sent from my iPhone using Tapatalk |
03-06-2021, 09:29 PM | #52 | |
That's what I figured, plus will raise the policy due to the added power your car has as well. IMO I'd just buy a new ZL1 OR get a used ZL1 under 3 years, 36,000 miles old that still has warranty. |
03-07-2021, 09:12 AM | #53 |
Actually it was cheaper to insure the 2017 ZL1 as compared to the 2016 2SS I owned and I couldn’t understand that because of the extra hp and it being a more expensive Camaro. It might have been because it was a used car instead of new but I surely didn’t question it for long though.
03-07-2021, 02:29 PM | #54 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Keep in mind when debating whether to SC a SS or buy a used ZL1, in buying the ZL1, you are getting far more that just an engine with more HP.
You also get an entire drivetrain designed to handle that additional HP/TQ including but not limited to, heavier duty axles and a (in most cases) a bulletproof rear end, etc. |
03-07-2021, 02:44 PM | #55 |
Drives: 2020 Callaway Camaro SC630 Join Date: Feb 2020
Yes.
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue |
