07-18-2018, 11:59 AM | #43 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
At CamaroFest 8, there was an SS manual and V6 1LE that I had an opportunity to shift through the gears while the car was parked. I've been with the Hurst setup for so long that I forgot how long (not a bad thing) and sloppy (relatively) the stock shifter was. The Hurst shifter / stock knob is much more precise! Hurst needs to get this to market ASAP!
I was hoping there would be an SS 1LE there so I could test out that shifter and compare the two. The overall design with linkage makes it tougher to create a good feeling, precise shifter. My 4th gen shifter that was connected directly to the transmission felt better than all of the above! If only they could have shifted the engine/trans back 6" or so, the same style shifter could have been used.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
08-01-2018, 07:44 PM | #44 |
A question was raised on what the stock SS shifter's design looks like and if there's anything that can be done to stiffen it up without going to a shorter throw.
The pics below show the linkage. The front part that attaches to the transmission is a machined metal interface (no real slop to speak of). The rear part that attaches to the shifter lever appears to have a hard plastic bushing (also not a whole lot of slop at this interface either). I don't really see any low hanging fruit to go after to stiffen up the stock unit. There's only so much that can be done with the linkage design as compared to ones that attach directly to the transmission (like the 4th gen F-body). With that said, even though I really didn't want a shorter throw than stock, the Hurst setup definitely stiffens things up and is much more precise/crisp than stock. The spherical metal bearing on the Hurst shifter compared to the plastic spherical bearing probably helps some, but it's probably mostly due to the pivot point change.
08-17-2018, 11:00 AM | #45 |
Drives: 2016 Camaro SS Join Date: Nov 2015
It's (almost) here!
You've patiently waited, it's been a long time coming but it's finally here! Today we received word that the new Hurst Billet Plus Shifter that allows you to keep your OEM Chevrolet shift knob will be available on September 1st! This shifter provides the same benefits as our other Hurst Billet Plus Shifters, such as a massive reduction in throw and a limited, lifetime warranty.
This info is so new that we're still awaiting additional details so please subscribe to this thread, more information to come. Questions? Please call 707-544-4761 or visit www.hurst-shifters.com for additional application and product information. |
08-19-2018, 10:43 AM | #46 |
? Is the upper stick going to be available for the those of us that already have your shifter and just want to change back to stock knob , or is this a total kit only.
08-20-2018, 01:06 PM | #47 | |
- Jason @ Hurst |
08-23-2018, 09:58 PM | #48 |
Drives: 2017 SS 6sp Join Date: Jun 2014
waiting!!!
08-30-2018, 06:02 PM | #49 |
The shifter dropped a day early! You can now purchase it on our website www.hurst-shifters.com. If you're looking for the upper stick that allows mounting of the OEM shift knob I am still working on getting the necessary info, hang tight.
- Jason @ Hurst |
09-06-2018, 03:06 PM | #50 |
Drives: 2018 ZL1 1LE Join Date: Jan 2018
I have a 2018 ZL1 1LE, which to my understanding comes with a GM Short throw shifter. I'm not a fan of it, still feels sloppy compared to my MGW in my vette. Would the Hurst improve upon the "GM Short Throw" in terms of throw distance and crispness? Also, is it compatible ?
09-06-2018, 03:15 PM | #51 | |
Drives: 16 Camaro 1SS & 82 Silverado C10 Join Date: Mar 2009
Ordered 1SS Black on Black, M6 in late summer 2015.
Hurst shifter, Soler Performance ported TB. |
09-07-2018, 08:06 AM | #52 |
the gm 1LE shifter is only 6% shorter than the SS shifter. The Hurst is 40%
09-10-2018, 09:42 AM | #53 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Just ordered the upper stick for oem knob. 57.75+shipping
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
09-10-2018, 01:24 PM | #54 |
just ordered my shifter. they are doing 15% off right now $246 shipped is a good deal http://www.hurst-shifters.com/produc...r=&md=&sm=&e=#
09-13-2018, 02:47 AM | #55 |
Drives: 2017 SS Join Date: Jun 2018
So I am working on a project that will allow me to attach the Hard drive shift handle to this shifter. Is the upper portion that the shift knob attaches to steel by chance so that it can be welded ? Really sad that you went away from this interface for the shift handles and discontinued the Hard drive handle
09-13-2018, 10:15 AM | #56 | |
