08-11-2022, 06:12 PM | #43 |
Drives: 21 ZL1 Join Date: Feb 2022
When the fluid boils, it introduces a ton of bubbles. It doesnt boil away. So when it cools, the pressure goes back up and you have pedal again.
08-11-2022, 06:14 PM | #44 | |||
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
Furthermore, fading, or vapor lock is a function of time, and doesn't simply appear. I have boiled the factory brake fluid in my BMW M2 at Hockenheimring. And I can tell you first hand that it was a very progressive affair over 2-3 laps. With the pedal getting progressively more spongy, and decel fading away towards the end of each brake zone. He is pushing, and making mistakes, no doubt, but the brake system is more than capable to absorb it. Here is a number of laps in 90F heat at Mid O where I pushed the boundaries of my SS 1LE with no issues. Also not ideal brake points, or entry speed. But no problem at all. and in case you start doubting my drivng credentials too, here is a sub 8 min Nurbergring Nordschleife lap in a stock N55 M2 with just pads and fluid. The ABS unit in all Camaros is also a Bosch unit. Very few have issues like this, and they were tuned by Bosch and GM engineers, so it makes me wonder if these is some sensor input causing this, and there are TONS of 1LE users in both SS and ZL1 versions having no issues. |
08-11-2022, 06:17 PM | #45 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
08-11-2022, 06:21 PM | #46 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
After watching the other videos, for sure the car should have handled that with zero issue.
Ken |
08-11-2022, 06:39 PM | #47 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
I would definitely agree that the problem suddenly appeared out of nowhere with no warning, that’s for sure. I also think I would remember if the pedal went to the floor.
Thanks for the feedback and the confirmation guys, I appreciate it
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
08-12-2022, 04:23 PM | #48 |
The GM dealership bled the brake fluid from the callipers today, they took pictures and showed / told me it looked great, just like new brake fluid, it also measured 0 % moisture at the calipers… this would seem to confirm that the issue is not boiling the brake fluid, thanks again to everybody for your time and your input, it is much appreciated!
08-12-2022, 11:42 PM | #49 |
Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
GunMetal, are you 'left foot braking'? I've seen/experienced when left foot braking, it can induce 'ice mode' more frequently.
Best regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
08-13-2022, 01:24 AM | #50 |
Yeah you bet I am, I’m hoping I won’t have to change my driving style with the change in EBCM though. Did you change your EBCM?
08-13-2022, 09:36 AM | #51 | |
At your next event, try to only accelerate and brake with your right foot. I think you’ll find outstanding brakes all session long! Best regards, Dave
08-13-2022, 10:11 AM | #52 |
I can left foot brake on my car but since it's a manual most of the time I'm right foot braking. Haven't had anything weird ever happen left for braking though.
08-13-2022, 10:33 AM | #53 | |
And we are sure and have verified that all the ZL1LE’s never get ice mode because it’s impossible for them to?
08-13-2022, 10:35 AM | #54 | |
If so, I think I’ll add the delay between acceleration and braking you’re talking about but keep left foot braking so I can smooth out the corners where I transition between trail braking and maintenance throttle at the apex
08-13-2022, 01:49 PM | #55 | |
Drives: 2021 2SS 1LE Join Date: Aug 2020
I'd be curious to hear from those who have experienced and found work arounds for ICE mode. Is ICE mode more likely to be invoked by more violent weight transfer from back wheels to front (fast lift off throttle followed by fast depression of brake to threshold)? If so, would rolling off the throttle followed by rolling on brake to threshold be a better solution? |
08-13-2022, 07:04 PM | #56 |
Drives: 2020 Camaro ZL1 1 LE Join Date: Mar 2021
Hey there. First, I’m relieved that you didn’t have a serious incident!
Second, you need to be very careful with left foot braking on track, especially with a forced induction vehicle. You can run it totally out of vacuum brake assist using aggressive left foot braking, and it will feel like you are pressing with all your might on the pedal and it’s barely stopping. I have a dedicated race car which is turbocharged and I have to be certain to wait about half a second between full throttle and full braking on one certain track entering one certain turn, or I’ll run it out of vacuum assist and can’t stop. It is possible (likely?) that by left foot braking it often that you’re inducing the issue. If I were you, I’d quit with the LFB. Good luck out there PS I hold racing licenses with SCCA, NASA, and VRG. I’m an Instructor for all the major groups. I’ve been doing on track stuff since 1994, and have lots of years of experience in many different cars. |
