#43 | |
![]() Drives: 6th Gen LT1 Join Date: Jun 2023
The SS has fixed caliper with 4 pistons. I'd like to see what is the diameter of the pistons in the SS and LT1. Then calculate the Pad surface. I'm sure the brake performance difference is not much. Most would say in a track day it matters, yes but the disc is what disspates the heat, not the caliper. So good pads should do it. I think being the LT1 has 245's in the rear end, it doesn't need that much brake pressure, hence the single piston caliper. Cooling wise the LT1 is missing the side coolant radiators. The rest is there. I honestly don't think the LT1 is much cheaper to build, the differences are minimal mechanically. Its just a marketing stun to sell a V8 car and not lower the SS trim prices. |
#44 |
![]() Drives: Chevy Camaro Join Date: Aug 2023
I ended up with a new 23 LT1 A10 and ordered it with Tech Package, NPP, Recaros, Red Calipers, and Decklid Spoiler. I got it for $42,800. To me it wasn’t worth the extra $4000 to step up to a 1SS at the time, tho I do wish the LT1 came with the 275’s in the rear and that we had the HD Cooling option for it with the extra 2 coolant radiators. Other than that I didn’t need all the fancy creature comforts for it. I originally bought this car for straight line stuff rather than track or mountains.
Now, I did end up with a 24 2SS 1LE M6 in Vivid Orange Metallic because I couldn’t pass it up. Someone ordered it, it came in, and they ended up backing out.
2023 Black LT1 A10
2024 VOM 2SS 1LE Manual |
#45 | |
![]() ![]() Drives: 15 RH Z/28, 23LT1VOM Join Date: Dec 2012
#46 | |
Long hauler
![]() https://www.camaro6.com/forums/showthread.php?t=614204 I can’t say 100% on the LT1 as from brake and rotor sites they list the same as other LT cars but some people mentioned they may have SS sized front calipers? The rears are the same as LT though. The Copper-Free Brakes (BCD) can be had on any trim LT1 or above. It’s what essentially killed the LT 1LE option as they didn’t allow BCD to be ordered or given to LT cars and easier to kill it than develop another brake option just for a small subset this late on Edit: although when searching the 2020-2024 Excel sheet, J55 shows for both LT and LT1 cars while J6G only shows for SS cars so I’m sticking with my table If yours came with the 6 Piston BCD could you tell me or PM me your VIN? I don’t see BCD for any LT1’s on the sheet so maybe they made a new RPO?
2016 1LT v6 - Totaled Happiness: Infinite Last edited by Bumbleboy92; 01-26-2024 at 11:40 AM. Reason: Edited chart |
#47 | |
#48 | |
Rotor is 30mm thick(measured). Diameter I will have to remove the wheel to see it. So 2 diameter options so far according to your info post. |
#49 | |
I think they have way more codes and configurations than what's showed in the RPO's As I said, mine is late 2023, C8Z51 looks like. 30mm thickness rotor |
#50 |
Just found this.... very specific
![]() J55 Brakes, Z51 performance J55 Brakes, Brembo 4-piston front, performance, 4-wheel antilock, 4-wheel disc J55 Brakes, Black Brembo front J55 Brakes, Brembo front, performance 4-wheel antilock, 4-wheel disc J55 Brake system, heavy duty J55 Brakes, Brembo V Performance front J55 Brakes, Heavy-Duty 4-wheel antilock, 4-wheel disc J55 BRAKE SYSTEM,HEAVY DUTY POWER https://decoderpo.com/pages/J.html |
#51 |
![]() Drives: '22 LT1 Coupe Join Date: Nov 2021
Is LT1 an SS?
Pretty much. The only thing LT1 lacks is SS extra weight and some items that mostly benefit SS at a road racing course, but not at a dragstrip.
Ironically, both SS and LT1 are sad kin on a road racing course as compared to their brethern with superior 1LE packages. Depending on the course, you will even find Camaro Turbo 4- and 6-cylinder models with better lap times than stock LT1 and non-1LE SS models. Blasphemy, right SS owners? Except they laugh at you when they take your lunch money. Many prefer their smaller engine 1LEs to the bloated LT1 and SS V8 models, since the smaller engined cars are better stopping and handling due to lighter weight and better chassis balance. They also have better fuel economy. So, while many arrogant non-1LE SS owners blindly criticize other Camaros and their owners, their "hallowed" SS cars are really mid tier. Just ask anyone with a 1LE package. Oh, and don't forget the top-of-the line ZL1 models (it's really not a Camaro if it's missing a supercharger and/or 650 hp) ![]() Otherwise maybe it makes most sense to simply appreciate all of the trim/model lines of Gen 6 Camaro, and their owners. This type of thinking respects owner choices, premised upon their situations, needs, wants, and value systems, and yours. Last edited by LT1gen6; 01-27-2024 at 08:52 AM. |
#52 |
![]() Drives: LT1 Join Date: Mar 2022
Long thread to just say:
An LT1 is not an SS. |
#53 | |
![]() Drives: Boat Join Date: Mar 2021
#54 |
Guys you're arguing about marketing names. The engineers literally don't care and are not involved in the Badges and marketing names.
They literally designed a V8 muscle car, with different equipment for different purposes and then handed the car to marketing to set the price points and names. Physics don't care about names or marketing. Most of the optionals are a rip off. The 7 or 8 inch screen cost the same, one is just ugly on purpose get another 1000 from you. The differential cooler only prevents gear failure by overheating. Doesn't give you more performance. 27 piston caliper in the back is not making a difference braking hard when 80% of the weight is transfered to the front. |
#55 |
