02-01-2017, 03:46 PM | #43 |
"Lohla"
315 Conti Extreme Contact DW
6mm spacer in the rear and relocated the harness in the drivers rear wheel well.
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
02-01-2017, 03:53 PM | #44 | |
Drives: Wife's 14' IS 250 Join Date: Mar 2014
Relocating harness, I noticed there are no videos showing the how-to. Is it a simple process? Sent from my iPhone using Tapatalk
-11% tint all around Ordered 2/06/16 Built on 3/22/16 Adopted 4/07/16 Sold on 2/05/16: 2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior: -Borla ATAK catback -Range AFM delete -15% tint all around -Red LED interior bulbs -55k white Cree LED fogs -License plate LED bulb swap -12" Sub Kit, BA amp swap -Oracle ghosted LED sidemarkers |
02-01-2017, 04:02 PM | #45 |
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
02-01-2017, 04:03 PM | #46 |
02-01-2017, 04:11 PM | #47 | |
"Lohla"
They are 5th Gen ZL1/1LE replicas. Same offset as the 5th gen. Not sure what that is, sorry.
02-01-2017, 04:24 PM | #48 |
Drives: SS-6-SPD Join Date: Jan 2017
02-01-2017, 04:56 PM | #49 |
315/35/20 tires rubbing issues?
I see the placement is shown. Did he have to drill holes to mount the zip ties to? So in short, to avoid all this one could just stick to ZL1 wheel offset & tire sizes, 305/30? Would 305/35 be an issue? Sent from my iPhone using Tapatalk
02-01-2017, 05:28 PM | #50 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
You shouldn't have an issue with the zl1 setup and tire size. 305/30 is actually the correct height. I'm still not sure why so many people are going with 305/35 except maybe to fill the fender gap a little.
02-01-2017, 05:52 PM | #51 | |
5th gen 1LE used 35 in the rears... but I'd like to use 35 also for reason you mentioned, fill gap. Has anyone reported rubbing with 305/35? Sent from my iPhone using Tapatalk
02-01-2017, 05:57 PM | #52 |
#becauseracecar
I could be wrong but I believe the 5th Gen had taller tires on all SSes. I wouldn't compare 5th gen to 6th gen sizes.
02-01-2017, 06:23 PM | #53 | |
No I'm not comparing, I used to have a 5th gen w/ 1LE but on my 6th gen I'd like to go for 35, just to fill the gap better.. just don't want to deal with rubbing. Sent from my iPhone using Tapatalk
02-01-2017, 10:19 PM | #54 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Some 305/35's will rub.
02-01-2017, 10:33 PM | #55 |
Cool, then I might just play it safe & stick 305/30 & get the GM lowering kit. Sent from my iPhone using Tapatalk
