05-23-2017, 06:22 AM | #43 |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
Sean, those look great, but I'm more interested in the results on track. I love NT-01s! I hope they work as well as I expect!
05-23-2017, 06:26 AM | #44 |
Drives: 17 ZL1 Join Date: Mar 2017
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
05-23-2017, 10:17 AM | #45 |
Drives: ZL1 1LE Join Date: Oct 2016
Rear comparison:
Current Setup: 19x11 +43 vs. 19x11 +36 = 7mm more poke over stock If I put the fronts on the rear: 19x11 +43 vs. 19x10.5 +14 = 22.7mm more poke over stock
05-23-2017, 10:51 AM | #46 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
So, if somebody wanted to run 10.5 rims square, it would make sense to use Sean's F offset and then adjust the R offset to still maintain 7mm poke which would retain stock track width (close enough).
05-23-2017, 11:41 AM | #47 |
I think if I were to try and run 10.5 square rims I would adjust offset a bit.
05-23-2017, 11:43 AM | #48 |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
I'd rather get 19x10.5 et22 x4 and run a small front spacer. That would poke 7mm more at the rear than Sean's but allow you to run identical wheels/tires (305 NT01) on all 4 corners. The ability to rotate front to rear at the track is huge.
05-23-2017, 01:02 PM | #49 |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
Just for the reference this is how the 18mm poke in the rears look like (The rears are 19x11" +25mm offset )
It doesn't really bother me as much so Provoste's 19x10.5" with 22mm offset plan for the rears (my front wheels) would not even stick out as much, ability to swap them at the track is great of course
05-23-2017, 01:32 PM | #50 |
I think if I were doing a custom 10.5 square I would look into 19 x10.5 +19 with a 5mm spacer up front. This would keep the same inner strut clearance on the front while also maintaining the same poke I have now. On the rears it would poke 17.7mm more than stock, or 10mm more than what is on my car above.
05-23-2017, 06:56 PM | #51 |
Agree: strut clearance is something to consider for sure. The second area is widening the R track, which may induce more understeer. I guess there are pros/cons here. Personally I'd go with Sean's set up which maintains stock track and worry about the tires separately.
05-23-2017, 08:43 PM | #52 | |
Drives: White 1LE Join Date: Dec 2016
That is exactly what I went with for my 305 square setup. Feels 100x bethere than stock setup |
05-23-2017, 09:03 PM | #53 |
Can you describe why it feels so much better please? Plus what tires.
05-23-2017, 09:14 PM | #54 |
Same tires as op
305/30 RE71r 19's I believe I get more feedback thru the tire to the steering wheel, stiffer & shorter sidewalls than oem 305/30/20. Daily driving is actually so much more enjoyable loosing 20 something pounds of rotational weight- acceleration & braking takes noticeably less effort. Road noise & ride quality are negligible I don't pay mind to either. I have not tracked them yet,.. but Turn in response seems m9re direct more predictable more forgiving. Not that 285s are insufficient up front. We've seen the crazy fast lap times with oem. Its comparing swimming in a lake vs an ocean. You'll 99% never know the difference.. but you want to go swimming both fulfill that desire more than we can use |
05-23-2017, 09:19 PM | #55 |
Got it - thank you! Still debating getting a second set of rims in 19s....
PS OP has NT01s on. |
05-24-2017, 03:26 AM | #56 |
Although I like the idea of sq setup wheels, I just didn't want to use anything narrower in the rear. To me it feels like a downgrade, when 305/30/19 tires put on 10.5" and 11" wheels you still get a slightly more mechanical grip due to size of the wheels. When put measured both the difference was exactly .5"=12mm.
Yes the ability of rotating tires has its benefits but NT01s are relatively cheaper than those Cup2s, Trofeo Rs, R7s .etc and I can always take it to a local Costco tire service and have them swap the wheels for $60, if I ever need to ( I didn't have to in the past)
