08-04-2020, 12:29 PM | #43 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
redundant gauges are super annoying.
The fake bs analog gauges in the camaro dash need to go. They _have_ to cost more to build and install than just making the entire dash area (where the driver gauges currently occupy) an lcd screen. make it one big lcd screen and allow the driver to place whatever gauges they want in whatever format and size they want on it (mandating that at least at all times some speedo gauge must be present). Give options for every different thing the ecu tracks. That should be trivial. Throw in some cool background options ... maybe set the odometer to be an e-ink display so the car doesn't have to be turned on to see it. our dash is sad. The infotainment system is sad. Just frowns all around. |
08-04-2020, 12:33 PM | #44 | |
Hot Camaro
08-04-2020, 12:35 PM | #45 |
Drives: 2021 2SS Join Date: Jul 2020
Anybody have actual data/statistics on the issues with AFM or is it just speculation of what has been 'heard' of by others? Is the primary concern oil burning?
I am sure if AFM was causing that many issues in the vehicles they are in, the engineers/designers would have corrected it by now in some form. It is to be expected when the tech was brand new, there would be some teething issues to work out, but by now, it is a fairly mature technology utilized in various vehicles. It debuted around what, 2007? 10+ years is a long time to improve things. Oil burning isn't just an issue for engines with AFM, obviously. My 4-banger Scion xB was burning oil and my dads Prius burned a quart nearly every 1,000 miles. I know of friends who had pretty significant burn in their 4 and 6 cylinder cars as well. I bet you proper break-in, oil selection and other factors are a much bigger influence on oil burn as the engine ages than AFM. Just my thoughts at least. I have a hunch the 'fear' of AFM is way overblown anymore. |
08-04-2020, 12:43 PM | #46 | |
Hot Camaro
The "data" is out there in some regards, largely in forums and posted by those that had issues. What's missing is the non-issue owners and specific details about whether other factors are part of the problems that were experienced. No manufacturer is going to produce a report for general consumption that says "let us tell you how bad this product is/was." Data is funny in that the more you have, the more you can potentially discount a lot of it. |
08-04-2020, 12:46 PM | #47 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Personally I prefer the C7 Corvette gauges myself(other than the useless speedo part), mainly the reconfigurable tach. And when I do more spirited driving, I don't really look at the dash that much. The HUD more than makes up for it IMO since I don't have to take my eyes off the road and it has features like shift light(very handy for a stick shift). Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
08-04-2020, 12:50 PM | #48 | |
50th Anniversary, 2SS, Build#5771, A8, MRC, NPP, NAV, Sunroof, GM Performance CAI, Trifecta Tuned, GM splash guards, Black illuminated bowtie, GM smoked tail lights & third brake light, GM Fifty floor mats, Strut tower brace, JWM side markers, 20% window tint, Sto N Sho front license plate bracket
08-04-2020, 12:53 PM | #49 | |
Hot Camaro
I think it's actually more related to throttle position than actual speed, and I have also found that the motor won't actually go into V4 mode if you're free-rolling downhill because DFCO already has all of the cylinders shut down. |
08-04-2020, 01:06 PM | #50 |
engine load. ... you can hold the same pedal position (which is roughly equiv to throttle position) and if the gradient of the road changes, it will kick you out of v4 or allow it to go into v4 mode. So it's not throttle position that dictates afm.
Also time. v4 mode is limited by how long it can remain as such because the engine can't allow those cylinders that are deactivated to get too cool. So it cycles between v4 and v8 for periods of time even if the engine load is all good for v4 the entire time. Also, gear. The car wont allow v4 mode in low gears. I believe that's done to prohibit v4 mode while stopped and likely to accelerate (as well as lower gears being out of the engine load limits for most throttle positions) |
08-04-2020, 01:18 PM | #51 | |
That's the big unknown... The percentage of people who actually have an issue, caused by AFM, relative to the number who don't. As you said, we will never know unless the automaker offers a notice/fix/recall. Data is a wonderful thing, if you know what to do with it. |
08-04-2020, 01:20 PM | #52 | |
Hot Camaro
Assuming either increasing pedal depression or cruise control, if the amount of power output in V4 mode is insufficient to maintain a speed or gain speed, then the car switches back to V8 mode. Incidentally, activating cruise control almost ALWAYS forces V8 mode to start. |
08-04-2020, 01:43 PM | #53 |
the behavior doesn't require any other numbers than time, gear, and engine load.
You can explain why it turns on and off at all times based on just those numbers. (ignoring performance shift / track modes that can prohibit it from engaging due those states specifically being active). There's no need for any other complex calculations or inputs. |
08-04-2020, 01:59 PM | #54 | ||||
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
08-04-2020, 04:30 PM | #55 |
Drives: SWXXZL1 Join Date: Jul 2020
GM calls cylinder deactivation DFM for it's newer production 5.3L and 6.2L vehicles now. Some early (conflicting) articles said the ZL1 Camaro A10 has the DFM.
Quote: "Dynamic Fuel Management (DFM), otherwise known as Dynamic Skip Fire, is a General Motors engine technology that shuts down the engine's cylinders to optimize power delivery and efficiency. DFM is an improvement to Active Fuel Management, which it succeeds." Adding to the confusion, RANGE TECHNOLOGY says their module will work with the DFM in 2020 camaro with 6.2L but doesn't actually specify ZL1/LT4/A10. Here's an article on DFM... https://www.enginelabs.com/engine-te...el-management/ |
08-04-2020, 04:45 PM | #56 |
Drives: Fast if no one's looking Join Date: Aug 2019
There are just certain cars in price ranges where the vast majority of the customers for those cars really don’t care about fuel economy. At. All.
Do people who buy a $130,000 S-Class Mercedes REALLY care? They’d be perfectly fine with the 6.3 liter V8 that came in the old 1960s Grosser which got about 8 mpg. The Camaro to me is one of those cars. If you feel the desire to even glance at your fuel average for any reason other than to laugh you’re doing it wrong. If you’re not in the teens you’re doing it wrong. |
