08-11-2020, 04:01 PM | #43 | |
Drives: 2018 SS 1LE Join Date: Oct 2017
2018 ZL1 1LE
1966 Corvette 427/425 vert 1969 Corvette 350/350 |
08-11-2020, 04:11 PM | #44 | |
Hot Camaro
So, again, aside from the fact that AGM batteries can be mounted INSIDE the car, I have found no specific benefits to it for the Camaro as compared to a standard Lead Acid battery. |
08-11-2020, 04:13 PM | #45 | |
Drives: gas powered Join Date: Jan 2019
if you had the key close or in your pocket the cars CANbus is active. The click whine noise you hear in the right rear is the fuel pumps when you open the door. A few checks would give you a good idea whats happening. Harbor freight throws a cheap meter in you shopping bag when you check out a few times a month. They are perfectly fine for checking DC voltage. Everything else is guessing....
08-11-2020, 10:45 PM | #46 |
Drives: A few Join Date: Oct 2017
Last time I started mine it sat for probably 3 months and started right up.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
08-12-2020, 08:56 AM | #47 |
I appreciate all the comments. And it’s wonderful to hear comments about other cars not having any issues. However,it would be more appreciated to hear who (if any) is having a similar situation as to help troubleshoot the issue
2018 ZL1 1LE
08-12-2020, 09:03 AM | #48 | ||
2016 NFG 1SS A8
08-12-2020, 09:20 AM | #49 | |
Hot Camaro
If the alternator is still putting out sufficient power to actually operate the car, then the logic portion of the charge circuit the determines how much power flows to the battery could effectively go into a "maintain" mode putting out virtually no power to the battery. With no power in the car needing to be "added" by the battery, then this wouldn't be an issue for the battery at all. OTOH, if the charging circuit slows down or stops, and the alternator's output is insufficient to operate the car, then the battery is being drawn upon and that's not good for it over the long run. |
08-13-2020, 11:51 AM | #50 | |
Naw my old 70's truck/cars discharges at idle older alts dont charge well at idle like these new ones do. Im trying to find out from a friend but I think you can use a GM scan tool and look at voltage over time to look and see how long the battery goes under 12 volts.
08-13-2020, 01:27 PM | #51 | |
Hot Camaro
