01-28-2019, 06:33 AM | #43 |
Who Needs to KNOW?
We need more data!
Let's get photo w banana for scale so we can see size of the crater i mean pothole
ing for grip.
04-03-2019, 06:10 PM | #44 |
Drives: 2008 Evo X Join Date: Sep 2018
So lets say , can we pull the fuse from SRS systwm for AutoX event or will thst cause a car to go into limp mode ?
04-04-2019, 04:43 PM | #45 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I have read that you can use a resistor to disable each side curtain airbag individually and I would like to look into this more. Hopefully it isn't too hard to access those two airbag wiring connectors so the resistors could be installed after arriving at the track/autocross event and removed before driving back from the event. |
04-04-2019, 08:00 PM | #46 |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
You might be able to reach the connectors by removing the C-Pillar trim. That is usually where the inflator is located. I have seen some instances where the inflator was mounted above the headliner.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
11-17-2020, 01:29 PM | #47 | |
another one
11-17-2020, 03:06 PM | #48 | |
Wow that is unfortunate. He was running Yokohama A052 tires according to the other video he posted the same day. I wonder if they were able to pull slightly more cornering Gs compared to the stock ZL1 Goodyear Supercar 3 tires causing an increased likeliness of side curtain airbag deployment.
I also wonder if the 1LE Camaros have had their side curtain airbags recalibrated to be less likely to deploy. Thankfully my airbags did not deploy in the video below but the curb hit was severe enough to require replacing a front wheel, lower control arm, and tie rod end. It also knocked the negative camber adjustment from max to minimum on that corner. I was sent the attached blurry photo that appears to show a big front wheel gap around when I slid over the curb...it is possible that one or both front wheels may have left the ground for a moment. |
11-17-2020, 03:44 PM | #49 |
Drives: 2020 ZLE Rally Green A10 Join Date: Sep 2016
Clearly the Camaro airbags are much much more sensitive than the Mustang airbags. My brother lost it in turn 10 at sebring with his relatively new Mustang. A lot of body damage to the passenger side from headlight to rear quarter panel, mirror broken off and wheels are rashed. No airbags deployed.
11-17-2020, 04:08 PM | #50 |
it seems like its mostly zl1 cars that have it happen not zl1 1le/1le ss cars weird right?
11-21-2020, 03:46 PM | #51 |
Man that sucks. For sure should not happen on a car with a track package, but they are sensitive and some more than others.
11-21-2020, 04:05 PM | #52 | |
Drives: ZL1 1LE Join Date: Jul 2020
If the tires had anything to do with it R7s would be setting off airbags left and right. |
11-24-2020, 08:23 AM | #53 | |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
If you'd like to try and argue with that, please feel free to watch the video for my rebuttal lmao |
