01-12-2017, 09:11 PM | #43 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
Are you still taking your audio input from the bose amp output or did you splurge for a MOST-to-non-proprietary digital signal and remove the bose amp entirely?
01-12-2017, 09:16 PM | #44 | |
Drives: 2017 FIFTY VERT MANUAL 2SS Join Date: Dec 2016
It does sound awesome. But I can't help but think that the entire stock headunit and Bose system/amp is preventing it from getting to that next level. Unfortunately, there are basically zero options for replacing the head unit and I have no idea what the MOST-to-signal pros vs. cons are. I'm all ears to someone who's tried that option. |
01-13-2017, 06:13 AM | #45 | |
Pills are for Pansies
Drives: 2023 2SS Red Hot Vert Camaro Join Date: Jul 2008
Notice the paint isn't in that area on the car. mine's the same way - are ALL the Camaros missing paint in this area? |
01-13-2017, 06:56 AM | #46 | |
Is the back-lighting of your "Fifty" logo always red, or is it synchronized to the interior color? |
01-13-2017, 09:57 AM | #47 |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
Looks great. Just curious how the footwell sub enclosure is secured to the car? Is it easily removable if you had to access something behind it?
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
01-13-2017, 10:17 AM | #48 |
Wow, that set up looks great. I've got a couple questions. Why did your shop suggest keeping the Bose amp? My shop suggested removing the Bose amp and putting in a JL Audio Fix86 between the stock head unit and the new amp to give us a flat signal. I understand that's what your DSP is essentially accomplishing, but wondering why the Bose amp was kept in the equation. Second, the footwell sub enclosure looks amazing, I'm wondering if you are getting any rattles from the bass? I noticed you Dynamated the doors, did they apply Dynamat in the footwell area as well? What was used for sound deadening?
01-13-2017, 10:25 AM | #49 | |
If your shop has some way to get a line level signal from the head unit, please let us know. There are some MOST decoders out there, but no one has found one that works for our car (yet). |
01-13-2017, 10:51 AM | #50 |
Couple answers to some of the questions above:
1. The FIFTY logo is only backlit in red. I have an Escort 9500 radar detector mounted under the rearview mirror that has a red display, and wound up keeping the internal LEDs on red, so I am simply going with a single color theme. 2. Sub is mounted to car with some sort of holding concrete clay. I can still smell it a little in the interior. It's definitely solid with no rattles at all. Scroll back in this thread -- I think I posted a pic before the carpet was put on and you can see the clay on the left and right sides of the sub. 3. I didn't ask why they chose a post-amp signal. Probably to keep all the factory functionality, I would guess. That's what they said they were doing and I didn't know a pre-Bose option was available. Per the last post above, apparently it isn't? (yet?). |
01-13-2017, 12:27 PM | #51 | |
Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
01-13-2017, 12:36 PM | #52 |
Drives: 2016 SS Convertible Hyper Blue Join Date: Apr 2016
My 1ss is the same way I had to keep the factory amp. IF we ever get some new head units available maybe we can ditch the factory amps.
Blacked bow ties, full bigwormgraphix blackout
Gm splash guards Mishimoto catch can Black hash marks Curb alert Vitesse controller Jl audio HD 900/5 amp c5 650 components c2 650x coaxials rear fill 2 x 8" W3v3 subwoofers custom ported box Fix 82 module BF TPNS BF Wet Diamond BF Crystal Seal Hydr02 303 Aerospace top protectant |
01-13-2017, 12:58 PM | #53 |
What is needed is someone to test something like this
http://car-solutions.com/en/car-most...-bos-mi009.php There is an HMI multiplexer device that is known to work with 5th gen camaros and it does have audio-out RCA connectors, but it's unclear if it works wtih the 6th gen and unclear if those connectors capture all audio heading towards the bose amp or only a subset. |
01-13-2017, 04:41 PM | #54 |
I don't know enough about MOST encoding, and every time I google the topic I fall on my face because "most" is both an ambiguous and common word!
I am not sure if there is a standard way audio is inserted into the data stream. A whole frickin' internet out there with tons of coding guidelines... yet MOST is like hieroglyphs before the Rosetta stone. I hope our implementation of MOST is shared across multiple GM products which should create enough of an opportunity for someone to manufacture a decoder for aftermarket audio. |
01-14-2017, 02:35 PM | #55 |
I wrote JL customer service directly to get a straight answer on the FIX86 and its placement in the system. Their reply is below. You were absolutely right ctrlz. I guess that's why I haven't pulled the trigger on my upgrade yet, b/c even the high end custom shops in my area still don't have enough knowledge on working on our cars yet. However, I will point my shop to this thread as it's by far the best when it comes to replacing a Bose vert system. Thanks again for starting this thread!
Carlos Chavez (JL Audio) Jan 13, 15:26 EST Hello, Correct, you'd have to place the FiX-86 in line between the OEM amplifier and the aftermarket amplifier. Be aware you'll probably need to disable any Active Noise Cancellation in that vehicle as well. |
01-14-2017, 04:24 PM | #56 |
I did some thorough searching on MOST today and had much more success than previously! I'm not sure how much it will really help, because GM's implementation of MOST is still unique to GM.
For reference, our Camaros use MOST50 over copper for communication between the audio components. First my big find. You can download (for free) an entire book (in English) on MOST from this location: http://www.mostcooperation.com/publications/most-book/ There is some interesting stuff on audio around page 300. Second, to get the most specific information on this topic, it is worth searching Camaro6 for posts by gblaue. He keeps a low profile, but one can quickly infer he has a firsthand working knowledge of Bose amplifiers, but not the exact amp in our car. I get the impression we are unlikely to see a MOST-to-lineout audio decoder unless Chevy itself decides to produce one. |
