02-06-2024, 06:31 PM | #43 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
A little update...
In the process of moving the ABS, Fusebox, and ECU into the cabin filter area. Fabricated Brackets that are removable for "service" of any of the components. First up, design and print a mount for the ECU that isolates it from any ground. Next, mount to frame that the Fuse box sits in. ABS mounted and attachment points for the Fusebox mount. Frame mounted. Utilized stock mounting bolt for the Fusebox. Fusebox mounted. Side shot, plenty of room for activities! Cabin filter box mounted. Note the rain gutter has been reconstructed to allow for this. Not going to fit all of this otherwise. Cowl cover fits fine! Next up is welding, grinding, and filling all the holes and seems under the hood. Stay tuned.
02-07-2024, 01:15 AM | #44 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Man you definitely have your work cut out for you!
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
02-07-2024, 06:59 AM | #45 | |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
02-07-2024, 09:06 AM | #46 | |
I'm taking my time and not rushing through it, I have no timeline of when it will be done. If I don't feel like working on it, I don't. If I get irritated, I walk away. That's crucial. I've done all this before on my last 4th gen. While I was happy with the result, I didn't have the time to "really" get it where I wanted it and it was stressful. I guess what I'm trying to say is time is the biggest factor and how much you are willing to spend on it. Minimal brain capacity required. LOL I've seen the work you do, and I have no doubt that you could do that same with a major "time" investment.
02-07-2024, 09:07 AM | #47 |
Just chipping away at it!
02-07-2024, 09:20 AM | #48 | |
Anthony S
The 5th gen is a pretty nice starting slate and there is decent room to work and move around in there.
02-07-2024, 09:35 AM | #49 | |
02-07-2024, 03:16 PM | #50 |
Awesome work! Sorry if I missed it somewhere but are you having to extend any of the wire harnesses with that move?
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
02-07-2024, 05:20 PM | #51 | |
Most of the wiring will actually have to be shortened to fit proper.
02-07-2024, 08:03 PM | #52 |
Tri-County Camaro SWFL
You're build is definitely unique. Sweet car and awesome build.
Can't wait to see the AGP twins on this thing. You'll love them.
02-08-2024, 02:01 PM | #53 |
Oh wow. Quite the opposite of what I was thinking. I may look into this to clean up that space.
02-08-2024, 02:29 PM | #54 |
Ironically, I was getting setup to start the install of the turbos, and started chasing a squirrel. This is what happens when I am not supervised
02-08-2024, 02:32 PM | #55 |
Probably on Saturday, I’m gonna lay things out to know more of how much gets shortened or lengthened. I will document it somewhat and let you know.
02-08-2024, 04:33 PM | #56 |
Thank you sir!
