Old 04-21-2013, 03:13 PM   #43
MikeMoach
MikeMoach's Avatar
Drives: 2010 RJT 2SS/RS
Subscribed
I only got to read the 1st couple post but thanks for all the info, ill definitely be needing this soon
MikeMoach is offline   Reply With Quote
Old 04-22-2013, 02:51 PM   #44
MikeMoach
MikeMoach's Avatar
If I read this correctly, your saying that the sway bars do not need to be clocked/timed right?
I just installed mine and I tightened them down when the suspension was hanging and the car was on jack stands, so what I understand I should be good with how I did it correct?
Old 04-22-2013, 02:57 PM   #45
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
You are correct. Sway bars do not need to be clocked since their bushings do not have the same inner ferrule which locks to the chassis when tightened down. Their bushing are free to move by design.
Retro69 is offline   Reply With Quote
Old 04-22-2013, 03:10 PM   #46
MikeMoach
MikeMoach's Avatar
Originally Posted by Retro69 View Post
You are correct. Sway bars do not need to be clocked since their bushings do not have the same inner ferrule which locks to the chassis when tightened down. Their busing are free to move by design.
Ok thank you, so to save myself time and energy I should install my 1" drop springs next and then clock all my bushings as I change them right? And then I could get an alignment with out having to worry if the mechanic did it right or not cause I would have alrdy done it correct?
I think I'm right but just asking to make sure
Old 04-22-2013, 05:48 PM   #47
Retro69
Retro69's Avatar
I tried to clock my bushings after installing my drop springs but didn't feel comfortable with the results. I ended up paying just a few more $ to the shop that did my alignment. Very glad I did.
Sent from my DROID BIONIC using Tapatalk 2
Old 04-22-2013, 05:58 PM   #48
MikeMoach
MikeMoach's Avatar
Well I have new toe rods nd trailing arms with outer trailing arm bushings so I know I can do those right, for the others ill give it my best shot and if it doesn't work ill get the shop to do it and make sure that's right
Thanks for the info I appreciate it
Old 04-22-2013, 06:37 PM   #49
Retro69
Retro69's Avatar
Sounds like you're doing the exact same thing I did. I just installed Pfadt drop springs and ZL-spec sway bars with the new rear lower control arms.
Old 04-22-2013, 07:11 PM   #50
MikeMoach
MikeMoach's Avatar
Nice set up, I went with a bmr kit I also got the subframe bushings but doubt I can put those in myself, I know it's an adventure to install them
I have an understand where all the bushings are, but does anyone have or can take a picture closer to the car and point out where everything is like in the 1st post?
Old 04-22-2013, 07:20 PM   #51
MikeMoach
MikeMoach's Avatar
Wow sorry ignore the 2nd half of my last post
Old 05-02-2013, 11:21 AM   #52
A10maint
A10maint's Avatar
Drives: 2015 Z/28 #525
Hey all, I know it was asked already, but when it comes to timing the bushings. I know that the vehicle has to static, but can the front be on ramps with rear on ground and then vise verse. Or does the vehicle have to be level in order to complete the timing.
A10maint is offline   Reply With Quote
Old 08-08-2013, 08:07 PM   #53
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
I hate to bring back an old thread, but I am really thinking that I need to get this done ASAP! I installed Pedders springs about 2 weeks ago and the car feels extremely bouncy now. To the point that I almost prefer driving in Sport mode in my ZL1 because Touring is a constant bounce. I also don't see much of a drop in the front compared to other Pedders lowered ZL1's I've seen. Hopefully that will get corrected as well.
Deke736 is offline   Reply With Quote
Old 08-09-2013, 12:03 PM   #54
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
Still calling for this to be stickied!
K32 Camaro is offline   Reply With Quote
Old 05-29-2014, 03:16 PM   #55
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
bringing this back from the dead -
I have very loud "groaning" or "croaking" from the rear. Is this a result of that as well?
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 05-29-2014, 03:56 PM   #56
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Man, I learn something everyday on this website!
Great post and thanks for the info.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 06:53 PM
Timing bushings gtfitter597 Suspension / Brakes / Chassis 41 07-09-2014 11:02 AM
Put More Power To The Pavement With Pfadt Engine Mounts And Differential Bushings!!!! Apex Motorsports Transmission / Driveline 28 11-27-2010 10:46 AM
clunking after bushings and lowering rtkjadams Suspension / Brakes / Chassis 12 10-01-2010 10:56 AM
Urethane Bushings from Energy Suspension Bewenched Suspension / Chassis / Brakes 1 04-30-2010 05:12 AM
