#43 | |
I used to be Dragoneye...
...less than 1 second if you buy into the PDR lap time of 1:25.8x with the corrected tire pressures. ![]() And nobody ever tested Z06/base vs Z06/Z07 to get a performance delta for that equipment. I'd be very, very, very interested to see the results. |
#44 |
![]() Drives: Bucket Join Date: May 2009
A reveal for a road course Camaro at a Nascar event still seems far fetched.
The difference between the Z06 and the Z07 is more than brakes. IIRC a magazine reported that the difference was about 2 seconds at Road Atlanta. Last edited by Memphis; 02-21-2017 at 06:33 PM. |
#45 | |
Road Atlanta is of similar length and speed as Big Willow. Randy Pobst posted a 1:30 there in a Z06.... If the difference was about 2 seconds...Then it may be fair to assume that the ZL1 is as fast, or ~a tenth faster than a base Z06 around one of those tracks. And that applying the same "Z07" treatment to a ZL1 could very well keep that margin vs a Z06/Z07 Stingray. Absolutely incredible car....I just can't get over it. I remember back to when they were testing and Al O. kept going on about the car on facebook and other outlets, "You guys are going to love this car." "You won't believe how good this thing is", etc.....I get it now!! |
#46 | |
![]() ![]() ![]() Drives: A10 LT4 Join Date: Aug 2016
It's really gotta make you wonder what the new Z28 will do on the track now that we know the results of the ZL1...while I would still choose the ZL1 for the luxuries, sorta riveted to see what times this dedicated racer Camaro is going to turn!! Good stuff.
#47 | |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
#48 | |
Romans10:9-13
#49 |
![]() Drives: ///M3 Join Date: Nov 2016
Anxiously awaiting for my ZL1 delivery or the prospect of a Z28 decision.
#50 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS M6 Join Date: Nov 2014
#51 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 21 Bronco Join Date: Jun 2012
I think it would close the gap, but the Z06/Z07 is from what is out there now, the fastest vehicle in the GM stable. I just don't see a Camaro topping the current top of the line Corvette. And that's not a protect the Vette statement, just IMO the Corvette would still have the edge in just about every performance measurable, I don't see how sticky tires and better brakes would make the Camaro faster or just as fast, close the gap yes, faster or just as fast I don't see it. I look at the C6 Z06/Z07 which lapped Laguna Seca in in 1.34.43. Still 3 seconds faster than the Z/28 when they had the same power plant. |
#52 | |
Just look at how close the track times are. 1:25.00 around Big Willow. ZL1 manual did that same track in 1:26.16, without the benefits of Z07-style equipment. According to PDR, the properly-set up A10 car did it in 1:25.8x... As great as it is...and it IS...the Corvette is a handful, and for the past two generations, has struggled to put its power down efficiently...which is one of th bigger reasons (theoretically) that is driving this shift to mid-engine... Other factors in this discussion include high-speed drag, which hold the Z06/Z07 back in acceleration on long straights. Using the wing-style spoiler, the ZL1 gets around a lot of that... |
#53 | |
Let's look at everyone's favorite track to talk about on the internet the Ring. Current ZL1 did it in 7:29.60 C6 Z06/Z07 Did it in 7:22.68 C6 ZR1 did it in 7:19.63 I would assume and I know thats dangerous lol that the Current Z06/Z07 splits that difference(or might even be faster as the C7 Z06/Z07 has been faster on some tracks than the ZR1). I don't see sticky tires and better brakes putting the ZL1 in that range. Closing the gap you bet but being faster I just don't see it and I am not trying to knock the Camaro, I guess I just am pessimistic and keep my hopes low so I get surprised more often lol. |
#54 | |
![]() In any event it's hard to compare those cars...the C6 platform was lighter in every trim than the C7....for example, the old Z06 was a 3300 lb car....it's now 3500...and the old car, while it couldn't keep its power down at all, didn't suffer from as much high-speed drag as the new one...which would kill it on the Nordschliefe's long straights. It's one of the reasons I wonder why there has been no Corvette Nurburgring lap times to-date...perhaps they couldn't best the last-gen ZR1 with all that drag? It's a fast track...certainly not saying anything bad about the new car. But you could look at the 5th gen ZL1...7:41...and the Z/28 7:37 (wet)...that car was significantly down on power, but the tires, suspension, weight were the primary reason lap times improved, because it could hold significantly higher speeds through the corners. That is evidence that tires can make a huge difference. Furthermore...in 2006, when the Z06 first came out, well before they developed the Z07 package...the car did a 7:42 around that track....that's the same time as the 5th gen ZL1................ And finally...the original ZR1...pre-Z07 package, and I think they called it the "Carbon" package at the time...in any event, it put up a time of 7:26.4 around the Green Hell's north loop...after the package (tires), and some practice...they were able to hit the 7:19 mark. I'm not attempting to predict the future...and all this talk about sticky tires and Z07 packages with regards to the ZL1 is pure theory...but I am confident, that IF the same treatment (stiffer suspension, more aggressive aero, sticky tires, and bigger CCM brakes) was given to the ZL1...we'd see a Z06/Z07-beating time...even if just by a sneeze. It's also worth mentioning that I'll bet the Corvettes going around the 'Ring were 1LT trims....no nonsense...that's not even an option in ZL1, and likely at the penalty of an extra 25-40 lbs of "stuff"... Regardless...I hope we can all agree the Zl1 is DAMN QUICK...and to make a Z/28 go faster around a track will require some Al Oppenheiser-style witchcraft... |
#55 |
All sound logic it would be interesting to see.
back to our regularly scheduled programing |
#56 | ||
+1 Quote:
I think the Z?28 will inherit the top spot, for a short time only, the Corvette will get it back as soon as the new mid engine is out. Cant see how GM can sale the new Z/28 under $80K if the last car was $76K, that will be the lowest increase in price going from 5th to 6th gen model to same model. |
