03-11-2022, 09:38 PM | #43 |
Drives: 2018 Chevy Camaro 1ss Join Date: Nov 2020
Pictures
03-11-2022, 09:40 PM | #44 |
03-11-2022, 11:34 PM | #45 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
Hard to tell from the pics.. the first one is kinda blurry and the second one there appears to be pits and little metal chunks.
Are there pits in the crown and/or the head chamber?
03-12-2022, 12:52 AM | #46 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
03-12-2022, 05:13 AM | #47 |
It not pits,it's little drops of antifreeze. It's the back cylinder so it's almost impossible to take a good picture,but if you look close there are darker vertical streaks on the cylinder wall.
03-12-2022, 05:17 AM | #48 | |
03-12-2022, 07:17 AM | #49 |
Thanks for the pics. Would love to see the piston when it comes out too. Ive seen the log and seeing the associated damage helps to put the bigger picture together for me.
03-12-2022, 08:21 AM | #50 |
Dumb Ass Deluxe
Pics are awesome and thanks for the clarification. It's hard to get to those back cylinders.
Pull the piston and maybe you can get a better pic. On both I see the bore marks, but the first one is blurry, and it looks like that area on the piston crown by those bore marks is pocked. Hard to make out what's up in the second pic (piston wise). On the other side of the coin, if you did lean out, that would/could cause seizing. The skirt and crown to the first ring will have more clues as to what happened too.
03-12-2022, 04:55 PM | #51 |
03-12-2022, 05:44 PM | #52 |
Dumb Ass Deluxe
Pics of the crown and the skirt, please?
03-12-2022, 05:53 PM | #53 |
Crank looks good ,but looks like the bearings took a hit
03-12-2022, 06:02 PM | #54 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
03-12-2022, 06:07 PM | #55 |
03-12-2022, 06:57 PM | #56 |
What oil are u running?
