Old 02-03-2009, 12:20 PM   #533
nester7929
Rice Harvester
nester7929's Avatar
Drives: 2014 Bright Yellow 2SS/RS
Originally Posted by GatorBlue371 View Post
closer curb weight, all in all, similar straight line performance
At a cheaper price.
nester7929 is offline   Reply With Quote
Old 02-03-2009, 12:44 PM   #534
GatorBlue371
GatorBlue371's Avatar
Drives: vrooooom vrooooom
Originally Posted by nester7929 View Post
At a cheaper price.
Right.
We'll see, if you notice the $$ on the Stang they tested with all shiny's was over the MSRP of the Camaro.
Thats without all the new fancy equipment which its rumored to have.
"With a light touch on the brakes, run the revs up a bit. Slip off the brake and bury the throttle. There's a light chirp as tires scratch for bite. Then comes a sub-5.0-second sled ride to 60 mph. A tick over 13.0 sec. and you're through the quarter-mile. It's a rush, of course, but not overly dramatic. Try the same thing with this pair's predecessors of 1970 or so and you'll find yourself in a bit of a wrestling match. Ain't progress wonderful? Maybe yes, and maybe sometimes it's fun to wrestle."
GatorBlue371 is offline   Reply With Quote
Old 02-03-2009, 12:52 PM   #535
Bocephus
Drives: 2011 Mustang GT, Kona, BBP, 3.73
Closer in curb weight? How do you figure? The Mustang will still have at least a 300lb advantage.
Bocephus is offline   Reply With Quote
Old 02-03-2009, 01:03 PM   #536
MerF
Go Rays!
MerF's Avatar
Drives: 03 Trailblazer
Right.
Exactly.
MerF is offline   Reply With Quote
Old 02-03-2009, 02:42 PM   #537
LarkVille
LarkVille's Avatar
Drives: The Larkvillemobile
2011 Mustangs will still be solid axle correct?
LarkVille is offline   Reply With Quote
Old 02-03-2009, 03:38 PM   #538
GatorBlue371
again, the mustang crowd fails to make an educated attempt at arguments.
3572 lb . Thats how much this mustang weighs as a 5 speed (hahaha) manual.
Care to guess how much the Camaro weighs? Go ahead, lets get some numbers flying, how much is an SS 6 speed?
Then for the 2011 stang, go ahead and ad weight for safety equipment which they dont have, internals, and (god forbid) we might even think about factoring in the weight from an Independant Rear suspension...
At least 300 my ass.
Old 02-03-2009, 03:42 PM   #539
Georgie
Georgie's Avatar
Drives: Camaro... soon
the 3.5 Ecoboost is lighter than the 4.6 V8
Georgie is offline   Reply With Quote
Old 02-03-2009, 04:02 PM   #540
MerF
Go Rays!
MerF's Avatar
Proof?
Old 02-03-2009, 04:13 PM   #541
manimsoblack
manimsoblack's Avatar
Drives: 04 Pontiac Grand Am, 08 Ninja 650r
Originally Posted by MerF View Post
Proof?
"The 3.5L saves over 150 lbs. compared to the 4.6L V-8"
second paragraph
http://www.autoblog.com/2008/01/06/d...ect-injection/
Ford is using the 2008 Detroit Auto Show to kick off the transition of a significant portion of their engine lineup to what they are calling EcoBoost technology. EcoBoost consists of smaller displacement engines with direct fuel injection and turbocharging (GDTI) to provide a fuel economy boost without any loss of performance. Ford first showed the idea in the 2007 Lincoln MKR concept when it was called Twin-Force. The Twin-Force name has been set aside in favor of one that emphasizes the efficiency aspects of the technology. Thanks to the combination of small low-inertia turbos, the direct injection and variable valve timing, the new engines should have no lag and a much fatter, flatter torque curve.
The first EcoBoost engine out of the gate is the 340hp 3.5L V-6, This will be the optional engine in the Lincoln MKS starting in 2009 in place of a V-8. Besides having higher specific efficiency than a larger normally aspirated engine, the smaller EcoBoost units also save weight and size. The 3.5L saves over 150 lbs. compared to the 4.6L V-8 also helping contribute to fuel efficiency savings of up to 20%. Following the MKS with EcoBoost will be the Ford Flex and the new Explorer based on the Explorer America concept. The new SUV is expected to use GDTI engines exclusively, with a 275hp 2.0L four as the base engine and the 3.5L six as the option. Ford is by no means the first to do this, with Volkswagen pushing the tech for several years already on their TSI and TFSI engines. aMazda and GM also use the same principle. Ford really wants to make it mainstream, however, with over half a million EcoBoost engines annually within five years. Read more about EcoBoost over at AutoblogGreen.
Originally Posted by Kyle2k View Post
You take a shit on everything fun and good on this forum.
manimsoblack is offline   Reply With Quote
Old 02-03-2009, 04:27 PM   #542
Speedy1975
FASTER!
Originally Posted by truth411 View Post
http://www.motortrend.com/roadtests/...est/index.html
I must admit I am a little surprised.
3.73 gears
0-60 4.9sec
.95gs!! of lateral acceleration
60-0 in only 108ft.
3572lb curb weight
Though to get this type of performance out of the mustang, the price gap is virtually non-existant comparing the camaro. What do you guys think??
The suspension I'm sure helps, but those 3.73 gears are a biggie. The 3.45 gears in the Camaro will slow it down some.
Old 02-03-2009, 04:33 PM   #543
GatorBlue371
second paragraph
how much torque does the engine make
Old 02-03-2009, 04:40 PM   #544
manimsoblack
between 340 and 400. hp can be 340-415
Old 02-03-2009, 04:41 PM   #545
Georgie
Georgie's Avatar
it makes more power in rwd applications like the mustang and F150. right now its only in fwd/awd cars
Old 02-03-2009, 04:54 PM   #546
GatorBlue371
how much does it make in the MK
2010 Mustang picture! Twin Turbo General Automotive + Other Cars Discussion 20 11-04-2008 03:01 PM
Exclusive Spy Video: 2010 Ford Mustang camaro5 General Automotive + Other Cars Discussion 8 09-01-2008 08:48 PM
Watch out Mustang darthknight72 Chevy Camaro vs... 34 08-12-2008 06:19 PM
5.0L V8 could return in 2010 Mustang camaro5 General Automotive + Other Cars Discussion 15 04-18-2008 06:41 PM
