| View Poll Results: Who has experienced an oil pump failure? | |||
| 2016 or earlier |
25 | 14.97% |
| 2017 |
57 | 34.13% |
| 2018 |
77 | 46.11% |
| 2019 |
3 | 1.80% |
| 2020 |
4 | 2.40% |
| 2021 |
1 | 0.60% |
| Voters: 167. You may not vote on this poll | |||
Thread Tools |
#533 |
![]() Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Hey all, it has been awhile since you've heard from us. We will have an announcement VERY SOON. You won't have to worry about seeing another failure from an oil pump, put it that way.
#534 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Shame won't be in time for my build as we are changing the pump when we do the cam. Hopefully going in shop by months end.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
#535 |
![]() Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
Very exciting, excellent!
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
#536 |
GM would expect zero catastrophic LT4 engine failures and they would recall these cars if there were evidence of systematic defects so something's not right here. There should not be numerous LT4 oil pump failures.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#537 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
![]() I plan to take my engine apart over the winter months, and install a new oil pump, before my old one blows up. No GM warranty for my car here in Europe, so i'm not taking any chaces.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 Last edited by swisstyphoon; 08-21-2020 at 09:41 AM. |
#538 | |
![]() Drives: gas powered Join Date: Jan 2019
/LIKE
#539 |
![]() Drives: Camaro ZL1 automatic Join Date: Jun 2019
Ok everyone as you seen it took them 2 try’s to get my oil pump in however now I have the car back and it seemed fine, but it’s been a week and at first I was babying the car just to try and let the pump break in some. However at WOT I’m getting a bad stumble so we data logged it the car is calling for 2900psi from the fuel pump but the actual is only 1200psi. My low side pick up from tank is 78psi so it’s good, could I have ruined the fuel pump by driving the car with low oil pressure Or possibly rounded out the cam lobe? We didn’t see any metal in the oil pan or filter.. the car would return to normal oil pressure when on the gas the only time it would drop low was sitting at idle, so that’s why the shop assumed it was the sending unit at first and told me to drive it on up there.. we seen the car had learned a 10% increase for more fuel, it was learned.. we took that out tonseenifnit made a difference and it did not! 🤷*♂️ What next?? Any ideas I’m thinking replace fuel pump and white it’s out inspect cam lobe with inspection camera, gotta be one of the two if say.... I’m so pissed about this’n really needs to do something about this issue
#540 |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Ruined the fuel pump by driving the car with low oil pressure? GM hasn't used a mechanical fuel pump in camaros since they ditched carburetors back in the late 1980s.
Your fuel pump is electric. So, there is zero chance that your low oil pressure affected the fuel pump. There is another post somewhere about a voltage issue to the fuel pump that was causing starvation issues. I will see if I can find that for you...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#541 |
Try reading this one: https://www.camaro6.com/forums/showt...uel+starvation
#542 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Hold on. I would like to think I’m well versed in engines since I’ve built tons of stuff from BBC to SBF to stroked Mopars. I will say i don’t recall opening an LT engine yet. Just sayin.
But. Guys are changing camshafts to achieve a larger fuel lobe correct? I believe so. If this is the case and I’m pretty sure it is then low oil pressure can most definitely cause camshaft damage, which if the LT has a fuel lobe, I think there is a possibility his fuel problem could be from the low oil pressure. Again I could be wrong. |
#543 | |
![]() Drives: 2019 Camaro ZL1 Join Date: Mar 2018
"To supply fuel to the high-pressure direct injection system, there are two fuel pumps, an electric supply pump in the tank and a mechanical pressure pump underneath the intake. The mechanical pressure pump runs off a tri-lobe wing on the camshaft." |
#544 | |
![]() Drives: 2018 NFG ZL1-1LE Join Date: Jun 2018
#545 | |
#546 |
Who Needs to KNOW?
I think we can add another 2018 ZLE to that list. Waiting on dealer diagnosis.
