Old 10-23-2017, 09:53 PM   #533
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Originally Posted by Boosted4life View Post
I ran a 11.59 at 121 the other day with 7800' DA. I feel like the car has 10s in it at low elevation.
Yes. It definitely does.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 10-23-2017, 09:59 PM   #534
17CamaroZL1
Originally Posted by big dave View Post
Everything lined up for me on friday. -400 da, good track prep, 1.705 60', yet I could only run a 11.19. The pass before, I had a 1.79 60' but ran an 11.25. I should've run at least an 11.12 with the 1.70 60', given the normal rule of thumb. There's no doubt in my mind that this car has stock 10 second potential, with a lighter driver.
Awesome pass Dave!! Glad to see you getting her back down there where she should be! What was your mph? Man!!!! I wish I could get me some of that -DA and good track at the same time! I'm still hoping I get lucky before winter sets in.
12/26/2016 Ordered!
2/8/2017 Built!!
Old 10-23-2017, 10:23 PM   #535
laynlo15
Drives: 2022 Lt1 A10
So I see none have gotten into the 10's yet. I saw the graphs above and wanted to talk about what mine made and how quick it has gone. My SS recently made 669/635 on the dyno and the next weekend it ran 10.33@135 with 1.50 60ft. I think the heat is affecting the blowers performance if it is pulling a bunch of timing as it looks like the Lt4s are. I know a few have run very close to the tens with drag radials. I run a Maggie 2300 and my IATs are running about 120 on a 90 degree day. Even when I wasn't running race fuel and a bunch less timing I still ran 10.80's@129.88. The smaller blower and heat is killing the Zl1's. It would seem with the A10 the 60' times should also be better then the A8 with a lower 1st gear. I wish someone could figure it out. I think AEM Water/Meth injection could help with the IATs and possibly help lower the temps.
Old 10-23-2017, 10:27 PM   #536
big dave
Drives: 2017 ZL1
Thanks Dave! The da was good but the humidity was 90%. The mph showed 128. I was dead on with what my PDR was showing when I crossed the traps. But, I do know that the track's mph should be slightly lower because of the way it's calculated.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
Old 10-24-2017, 06:32 AM   #537
Blackdevil77
Blackdevil77's Avatar
Drives: 2008 Pontiac G8 GT, Shelby GT500
Well, it seems that if this car does have 10s in it from the factory, the stars have to align perfectly to make it happen. You need the DA, perfect launch and the computers have to be in a good mood. Definitely not as easy to obtain as it should be, given the mph which is frustrating.
Blackdevil77 is offline   Reply With Quote
Old 10-24-2017, 08:42 PM   #538
Boosted4life
Drives: 2018 ZL1 A10
https://m.facebook.com/story.php?sto...id=75402982111
Not sure if anyone saw this but it appears Cleatus ran a 10.97 with his zl1 in what looks to be stock form, however it is possible it has tires on it I couldn't tell. Fast forward to 6:20 for the run.
Boosted4life is offline   Reply With Quote
Old 10-24-2017, 08:56 PM   #539
Blackdevil77
That was done with a pulley, tune and not sure what else. Nearly 100 rwhp over stock.
Old 10-24-2017, 09:25 PM   #540
laynlo15
Hey, I'm one who wants to see these cars kick ass like they should. It takes 670 at the wheels to run low tens. You can't do it with the setup the Zl1 has. It probably needs to torque management takin out of it. That's gotta be holding the car back. Someone needs to do a drag pack like mine which will save 100 lbs. as the cars are already heavier then the SS. Maybe the A8 is a better drag tranny then the A10. I just figured the gears being closer together it would be jack the bear at the strip. Guess I was wrong on that one. Tune, rolling mass and blower holding it back for sure.
Old 10-25-2017, 08:38 AM   #541
17CamaroZL1
The car would surely put down a faster time than that. Cleetus was trying to stay 11.00 or above for that class, but went a little faster because he was also behind from the launch.
12/26/2016 Ordered!
2/8/2017 Built!!
Old 10-25-2017, 09:26 AM   #542
S.T.A.R.
Drives: 18'-1LE
Is it safe to say that us M6 ZL1 folks need a CAI, pulley and tune just to keep up with those of you with the A8/A10?
Tony
S.T.A.R. is offline   Reply With Quote
Old 10-25-2017, 10:37 AM   #543
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Well my car will be getting a handful mods over the winter. I’m very happy with the car and the potential, but I can’t wait for all the stars to be aligned to make a 10 sec pass. My 8 time slips are all over the place ranging from best at 11.24@126.05 - 11.56@123.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 10-25-2017, 07:23 PM   #544
big dave
Drives: 2017 ZL1
Well if the ZL1 isn't capable of a stock 10 second pass as I predicted it would, it will be interesting to see who can do it with the least amount of mods. I would be extremely disappointed and surprised if it isn't done completely stock, though.
I don't think I'll be able to do it with my loaded ZL1 and my heavy arse, but I think a much lighter driver and car should be able to sneak into the 10s
Old 10-25-2017, 07:38 PM   #545
Ron_Robinson1
I truly feel a tune alone would net 10s.
Old 10-25-2017, 08:22 PM   #546
Zl1steve
Drives: Zl1
I am very happy with my 11.10 but it did have a cai. Our best mph was 129 on a 11.16 run. Since then I have done pulley tune headers and throttle body. Have not ran it but t is a lot faster for sure.
Zl1steve is offline   Reply With Quote
