#505 |
#506 |
3P171 USAF Combat Arms
Drives: 2013 SS/RS Join Date: Jul 2021
I’m surprised people are using these to tow a Camaro. We used a 2022 with a few ATV’s on a trailer and I was not impressed at all.
#507 | |
That said, I would not use one to tow close to the max weight rating. |
#508 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Now the 3rd gen with it's 430lb of torque should be able to keep that load moving easier, and it has a max rating of 7,700 lbs, but I still don't think I'd want to do that...or at least, not real far.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
#509 |
Congrats Hartford! Happy to see you've finally got it! Hope you are happy with it.
#510 | |
#511 | |
#512 |
![]() ![]() ![]() Drives: 2017 Camaro 1SS, 2023 Colorado Z71 Join Date: Sep 2017
Thanks Prenger and gearhead!
Becky and Joe had a dedicated Colorado tow rig they’d use for their track days, and I thought also for dealer deliveries, so I wouldnt think too hard about it. Https://www.camaro6.com/forums/showp...72&postcount=6
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow |
#513 | |
Recalled user
Drives: '12 Camaro SS, '18 Colorado Z71 Join Date: Mar 2009
2012 2SS 45th AE LS3 M6 Borla ATAK Catback Kooks Stepped LT Headers CAI Intake Hexvents VMAX CNC Ported Throttle Body RX Catch Can Hurst Short Throw Shifter Pfadt ZL-Spec Stage 3 Suspension Forgestar F14 Tuned by Frost |
#514 |
You think a turbo 4 cylinder pulling 7000lbs up and down the Smokey Mountains is a good idea? Yay, more rolling roadblocks doing 45 in a 70 uphill. You do you, but that motor is going to be run hard and put away wet under those conditions. Proper tool for the job. Don’t forget to add in the weight of the passengers, all their stuff, and cargo as the GVWR for the 2023 Colorado Z71 is only 6250lbs.
#515 | |
#516 |
Good point. I haven’t looked at the size of the rotors to factor in heat sink. Does the Colorado Z71 come with a trans cooler or braided brake lines?
#517 | ||
2nd...if you want an idea of how these trucks do pull in hilly areas, TFL Truck did a video on pulling a 6,800lb trailer up the IKE Gauntlet with Andre's Trail Boss (which has 390tq instead of the 430tq tune). It did just OK. (not great, not bad) The truck was basically maxed out. Once he got up to speed it maintained the speed limit at roughly 3,000 to 3,500 rpm for the most part. Trans temps got hotter than one might want, but owners have noticed the transmission generally runs warm so maybe the temps weren't as bad as they seemed? His did not have a trans cooler...I don't think one is available from the factory but I could be wrong.
#518 |
I completely agree with your first point. Just because you CAN do something, doesn’t mean you SHOULD do it.
We were at the boat ramp just hanging out when this guy backs his boat in with a very sad looking Honda Ridgeline. So not being able to resist I asked him why and he got defensive right away (the uniform does that to people) and said “I’m in limits” or maybe “it’s under max” I don’t recall exactly. So I told him that’s fine I’m just curious and he said (to this I remember clearly) “it’s a lease”. I remember thinking someone is going to be writing nasty letters to Honda in a few years.
