Old 05-10-2018, 08:58 PM   #5139
SnakeEyeSS
SnakeEyeSS's Avatar
Drives: Camaro 2SS & ZL1
Finished one for the kids.
Learned that it's hard not to get another color/layer not to smear when what you are painting is so tiny. Going to try again, but this one is decent, but I think it's best to just use a sharpie intead of paint if anyone else is going to try.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red
SnakeEyeSS is offline   Reply With Quote
Old 05-11-2018, 11:36 AM   #5140
NEGXXIS
NEGXXIS's Avatar
Drives: 2019 Camaro SS A10
Originally Posted by BrianL View Post
Love your wheels and stance! Perfect in my eyes
Thank you so much !!!
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0” Lowering Springs - MRR 228 Wheels 20x10 and 20x11
RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453
SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/
NEGXXIS is offline   Reply With Quote
Old 05-11-2018, 01:22 PM   #5141
mendocino
mendocino's Avatar
Drives: 2016 Camaro
Install the amplifier and subwoofer!
mendocino is offline   Reply With Quote
Old 05-12-2018, 08:27 PM   #5142
wjones14
wjones14's Avatar
Drives: 2021 BMW M2 Competition
Installed the OEM molded splash guards, front and rear. Got them from Shopchevyparts.com for $93.75 each pair - $200 for all 4 including shipping. I bought the 2SS on Mar 17 and ordered the Summit White splash guards right away, but they were on backorder until I received them last week.
Really pleased with them! They do look somewhat "tacked on" but at the same time look like they were factory installed. What I like is the peace of mind that they will block some of the stones and tar that would have hit the rocker panels and rear fender otherwise. Not sure how much they will protect, but no doubt they're better than nothing.
The install took a couple hours total, but I took my time. I started with the rear because they're a little simpler. The steps are:
  1. raise the car and remove the wheels
  2. clean the area where the guards will contact the fenders
  3. degrease the area with the supplied alcohol swabs where the tape will stick
  4. remove the push pins in the wheel well liner
  5. attach the guard with the supplied screws, leaving it loose
  6. pull the tape liner from the tape and press the guards firmly to the fender
  7. tighten the 3 supplied screws
  8. reattach the wheels and torque to 140 ft. lbs.
The most difficult part is pulling the liner from the tape without ripping the liner. It's extremely thin, and on my first attempt the liner did rip almost immediately. The problem is that you can't really pull the guard away from the fender, so not only is the liner stuck to the tape, but it's also squeezed between the tape and the fender. What worked for me was removing the guard and then removing the liner from the tape, and then reapplying the liner very lightly to the tape, before lightly screwing the guard back in place. After that it was very easy to remove the tape liner with the guard in place.
The front guards were a little more involved because there's an additional step of adding a bracket first, which the front guards are attached to. The guards are attached to the bracket by 3 supplied 3/32" rivets. I didn't even own a rivet tool, so I picked one up at Lowe's for $20, and used a rivet tool for the first time in my life. Super easy.
Tools required:
  • jack pads to fit over the pinch welds
  • 22 mm non-marring socket for the lug nuts
  • torque wrench set to 140 ft lbs
  • rivet tool (for front guards only)
  • T20 and T15 torx screw driver
Non-marring lug nut socket (also available at AutoZone):
https://www.amazon.com/Titan-Tools-2...SM4/ref=sr_1_2
Polyurethane slotted jack pad:
https://www.amazon.com/dp/B074267MN3...pa_dk_detail_3
2021 BMW M2 Competition 6MT
2011 Candy Lime Green Kawasaki Z1000 (1/4 mile - 10.38 @ 129.61 mph - stock)
Previous: 2018 Summit White 2SS 1LE; 2015 MINI Cooper F56 6MT; 2015 BMW M235i 6MT; 2003 MINI 5MT; 2005 Mustang GT 5MT
wjones14 is offline   Reply With Quote
Old 05-12-2018, 08:32 PM   #5143
SnakeEyeSS
SnakeEyeSS's Avatar
No Camaro logo covering up the Pioneer logo?
And what about this?
GM part number 84092721 if you want one
Old 05-12-2018, 08:37 PM   #5144
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
Got a door ding repaired, drove around a little, and cleaned the lower door and rocker panels with bug & tar remover. Long day but worth the time and effort!
ssmike is offline   Reply With Quote
Old 05-12-2018, 08:41 PM   #5145
SnakeEyeSS
SnakeEyeSS's Avatar
I cleaned some bugs too. These cars are bug magnets, my other cars don't get nearly as many bugs. I thought it might be the yellow but I've seen a lot of posts like yours lately.
Old 05-12-2018, 10:03 PM   #5146
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
Tools required:
I had the same issue trying to remove the tape cover. On one side it worked as described but the other side the tape covering broke and I had to remove the screws and pry off the guard and remove the rest of the tape cover and reattatch like you had to. My advise is to remove it first then alingn the guard and put screws in.
craigss50 is offline   Reply With Quote
Old 05-13-2018, 12:31 AM   #5147
Cgocifer
Cgocifer's Avatar
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel
Definitely need more Camaro logos...
Cgocifer is offline   Reply With Quote
Old 05-13-2018, 12:33 AM   #5148
Cgocifer
Cgocifer's Avatar
Umm, Its spring. Lots of bugs out there.
Old 05-13-2018, 04:22 AM   #5149
Soleil
Soleil's Avatar
How did you get the pic of your Camaro into the monitor? That looks awesome
Soleil
Old 05-13-2018, 01:39 PM   #5150
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Used the easy access trunk!
Old 05-13-2018, 02:38 PM   #5151
RicSimonis
RicSimonis's Avatar
Drives: '17 2SS H50 Vert
Old 05-13-2018, 02:48 PM   #5152
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
Come on now!!
STYLO LT1 is offline   Reply With Quote
