View Poll Results: .
Camaro 0 0%
Mustang 0 0%
Voters: 0. You may not vote on this poll
Old 05-16-2010, 09:59 PM   #5097
THE EVIL TW1N
Drives: 2003 Cobra Convertible
Originally Posted by a_Username View Post
Yes the scale does include trucks. However, that doesn't degrade my source. The fact is if you can't include the weight of trucks, then why stop there? Why should we include a car (much like most trucks) that was made for an entirely different reason than a pony car?
it does degrade the source if you want to compare cars to other cars and not compare them to trucks. Pony cars were on the small side when they came out, and yes that was compared to CARS not trucks.
THE EVIL TW1N is offline   Reply With Quote
Old 05-16-2010, 10:02 PM   #5098
a_Username
a_Username's Avatar
Drives: 2010 2SS Camaro
Originally Posted by fazm View Post
not just cooler weather, but more seat time, im beginning to think evan smith might actually hit a 12.4x
He'll get better than that.
a_Username is offline   Reply With Quote
Old 05-16-2010, 10:02 PM   #5099
fazm
Drives: ex-500hp v6 mustang
12.2, 12.3?
fazm is offline   Reply With Quote
Old 05-16-2010, 10:16 PM   #5100
a_Username
a_Username's Avatar
Simply saying your right never proves anything. Our current pony cars simply do not have that much of a weight difference from the older ones, and the ones that do is due to necessary safety features.
http://neptune.spacebears.com/opine/safety.html
There's a certain breed of car person who always seems to pine for the old days. You know the guy; he's the one who claims carburetors are better than electronic fuel injection because they're easy to work on -- conveniently overlooking the fact that carburetors need to be adjusted a couple of times a year to run optimally, whereas a good EFI system will need to be adjusted... well, never.
This automotive Luddite is also likely to say something along the lines of "If I'm ever in an accident, I'd much rather be in some old tank than in one of these modern tin cans." Press for details and he'll get defensive, with a line like "Hey, if a Honda gets hit by a 1968 Chrysler Newport, which do you think is gonna come out better?"
The underlying assumption here, outside of the hyperbole, is that today's cars are featherweights compared to their peers of thirty years ago. However, there is little evidence to support that assumption. To find out the truth, three drivers put four cars on the same scale. Each car had a full tank of gas; after weighing the car, the drivers deducted their own weight and the weight of the gas to arrive at a "dry weight" of just the car with nobody in it and no fuel on board.
The 1998 Pontiac Firebird Formula checked in at 3,345 lbs.; the 1995 Ford Mustang GT checked in at 3,325 lbs.; the 1992 Eagle Talon TSi AWD saw 3,265 lbs.; and the 1970 Dodge Charger saw 3,485 lbs. There's only 140 extra pounds in the Charger compared to the Firebird, despite the Charger's extra inch and a half of height, two inches of width, and fifteen inches of length! Old cars may be large, but they're also hollow.
Another way to look at it is to compare curb weights of vehicles that served the same purpose then and now. The curb weight of a 2002 Chevy Camaro Z28 is 3,439 lbs.; the curb weight of a 350-powered 1967 Camaro was 3,384 lbs. -- the two cars weigh nearly the same. A 1964 Chevy Impala weighed 3,450 lbs.; today's Impala weighs 3,466 lbs. -- again, nearly identical. A 1962 Mini weighs 1,400 lbs.; a 2002 Mini weighs 2,500 lbs. -- darn close to double, which suggests that smaller cars have seen the greatest weight gain. The Beetle faces a similar girth problem, going from 1,720 lbs. in the 1960s to 3,005 lbs. today.
So where are these modern tin cans?
Then there's the question of technology. There's a lot of stuff going on under the skin of today's cars than there was 30 years ago, which helps explain why today's cars are so heavy. This chart points out many of the differences between two cars with relatively similar purposes:
Clearly, the late-model car is superior both for surviving an accident and -- perhaps most importantly -- for avoiding one to begin with. Add these features to the myth of the old-car weight advantage, and it's hard to imagine why anyone would prefer to be in an accident with an old car.
Usually, such assertions use a grossly outmatched "victim" car, such as a 1966 Cadillac Sedan de Ville against a 1990 Plymouth Duster, which makes the choice obvious. But the analogy can be just as easily turned around: which car is going to come out ahead in a collision betwen a 1971 Ford Pinto and a 1995 Lincoln Town Car?
Compare vehicles of similar purpose, and see which one is the obvious choice:
How will it feel to suffer a rollover in a 2001 Land Rover, as compared to a rollover in a 1961 Land Rover?
If a 2002 Camaro and a 1967 Camaro both go into a corner too fast, which has a better chance of staying on the pavement?
If a driver is forced off the road and hits a telephone pole, is he more likely to survive in a Mini built in the 1960s or in a Mini built in the 2000s?
Old cars are great fun, but it's important to recognize their limitations. And collision safety is definitely a limitation.
Old 05-16-2010, 10:24 PM   #5101
Black5thgen
Drives: 2007 C6
Does anyone post on Mustang forums anymore. I need to join a couple I guess.
Black5thgen is offline   Reply With Quote
Old 05-16-2010, 10:43 PM   #5102
fazm
where do you think they get the info from
Old 05-16-2010, 11:01 PM   #5103
a_Username
a_Username's Avatar
12.2, 12.3?
The Camaro has hit a 12.5, which is only 1/10 behind the Terminator (12.4). Therefore, in order for it to be faster than the Terminator it's going to have to hit 12.3+. I believe it'll hit that 12.3 eventually!
Old 05-16-2010, 11:59 PM   #5104
masterofpuppets
Pulling your strings
masterofpuppets's Avatar
Drives: My girlfriend crazy with car talk
Cool, it's a fast turd. Can not stand the back end. Everyone says it grows on you.....bull#%@&......if anything, I'm hating it more and more. I'd rather have a terminator then that.
masterofpuppets is offline   Reply With Quote
Old 05-17-2010, 12:01 AM   #5105
Sax1031
Drives: 2000 Mustang GT
I don't like the back end on either the GT or the 5th gen.
Both back ends look like total shit.
Sax1031 is offline   Reply With Quote
Old 05-17-2010, 12:03 AM   #5106
TaylorRyanSS
COTW: 12/13/10
TaylorRyanSS's Avatar
Drives: 1969 Camaro
thats your opinion something about the back of the camaro reminds me of a corvette
"Are you one of those boys who prefer cars to women? - I'm one of those boys that appreciates a fine body, regardless of the make."
1969 CAMARO JOURNAL: http://www.camaro5.com/forums/showthread.php?t=341239 | FACEBOOK: http://www.facebook.com/taylor.ryan.apt | GRAPHIC DESIGN: www.aptdesigns.net
TaylorRyanSS is offline   Reply With Quote
Old 05-17-2010, 12:04 AM   #5107
Sax1031
What I find funny is how full of shit Car and Driver is.
They ran a 13.2 in a 2011 GT. And then run a 13.2 in a 200lb heavier 2011 GT convertible.
Old 05-17-2010, 12:05 AM   #5108
Sax1031
Oh shit you mean looks are subjective. I think you are on to something here.
Old 05-17-2010, 12:18 AM   #5109
SS 376
SS 376's Avatar
Drives: 2010 IBM 1SS (Former)
OP posted the same thing at LS1Tech too. These Mustang guys are shitting their pants they're that happy.
It's a good thing in the end. Hopefully the Stangs guys will go and actually BUY the car instead of just posting on the internet and keep some Americans employed. And now that the 5.0 is getting close, GM will hopefully work that much harder to improve the SS.
SS 376 is offline   Reply With Quote
Old 05-17-2010, 12:21 AM   #5110
Sax1031
Naw just giving the retarded fanboys some perspective and putting them in their place.
Remember when the 5.0 was maxed from the factory like was said?
How about when it was said the 5.0 was going to have to have the 3.73 gear to compete?
Same kind of dumb shit that was said when the 03 Cobra came out.
Someone has to keep the ignorant in line. Of course you could always bury your head in the sand.
2011, 2011 mustang, 442trumpsall, 5.0, camaro, camaro lost!!!, camaro lost., carthatsucks, corvette, drag, fanboys anonymous, ford, ford mustang, glue factory, gluefactory, gt ss ssrs comparison ford, gtss, mustang, numbers, oldnag, race, tired nag, trolls, video
Camaro VS Mustang Mega Thread Beau Tie Chevy Camaro vs... 3644 03-09-2012 07:45 PM
Gran Turismo 5... No Camaro? 5thGenOwner 5th Gen Camaro SS LS LT General Discussions 111 12-06-2011 10:06 AM
Official 2011 Mustang GT info released nester7929 General Automotive + Other Cars Discussion 81 12-28-2009 03:13 PM
