Old 08-06-2019, 01:01 PM   #491
rallenrpd
Drives: 2018 Camaro 2SS
I too have noticed surge when I first start it up. It will idle and then surge 2 times before finally staying steady where it should be.
rallenrpd is offline   Reply With Quote
Old 08-06-2019, 01:03 PM   #492
MackSteelPrivateEye
Originally Posted by All2Easy View Post
I have about 500 miles on the car since installation with the slight surge I noted above still being present.
Well, hopefully this will NOT be a common issue. I would think 500 mi. would be plenty of time to go through the recycle.
Old 08-06-2019, 01:04 PM   #493
Mighty Mouce
Drives: Camaro
How many miles on yours since the install?
Mighty Mouce is offline   Reply With Quote
Old 08-06-2019, 02:08 PM   #494
Kmeleon
Drives: 2018 NFG 2SS 1LE!
I'm very hopeful for the Soler unit. It would be greatly appreciated if you guys keep posting as you turn miles on the performance of the unit and whether or not it starts to revert to old behaviors.
If not, I'll just put the $$ into a tune for the same price.
Kmeleon is offline   Reply With Quote
Old 08-06-2019, 03:19 PM   #495
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
Originally Posted by MackSteelPrivateEye View Post
Yeh...exactly my symptoms too. Only feel the surge in casual takeoffs from a stop. Its about 1800 to 3000rpm. Also first startup in the morning just before the idle settles to 650 rpm it will surge up a few rpms for 5 or 10 sec. before going back to 650. Did disconnecting your batt fix it or you still have it?
Hi Mack, that is normal, the colder it is the longer it will try to idle at higher rpm's, somewhere between 650-1100. The goal is to heat the oxygen sensor to enter closed-loop fuel control ASAP. Has it gone above 1150 rpm? That wouldn't be normal.
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 08-06-2019, 03:22 PM   #496
It needs to learn to idle w/ the new TB, that is perhaps the TB's hardest task. If it keeps doing it after 5 starts (w/ cool downtime in between starts), please let us know.
Old 08-06-2019, 03:28 PM   #497
CamaroJD, Alltoeasy,
You both seem to have run the TB long enough; would you contact us through e-mail or call? We'd like to help you.
Old 08-06-2019, 03:33 PM   #498
All2Easy
Drives: 2015 Z/28 #997 Gone 2019 SS 1LE
You both seem to have run the TB long enough; would you contact us through e-mail or call? We'd like to help you?
Thanks Mike-
Will do so before the end of the week.
Overall, extremely happy with your product. The slight "surge" I am getting is by far not a deal breaker, and am sure there is a plausible solution if most are not experiencing the same.
Cheers!
All2Easy is offline   Reply With Quote
Old 08-06-2019, 03:42 PM   #499
Racerman27410
Racerman27410's Avatar
Drives: 2016 SS 2SS
Ive got about a thousand miles on mine after the TB install and everything seems to be done as far as the ECU learning goes.... i had a few erratic idles and what felt like a mild stumble at light throttle around 2000rpm in sport mode for awhile but all that cleared up long ago.
Still very happy with this mod.
Racerman27410 is offline   Reply With Quote
Old 08-06-2019, 04:44 PM   #500
MackSteelPrivateEye
I've got about 120miles on mine with all types of driving with probably at least 10 or 15 engine starts during normal driving. still have the surge at cold start up, and mild acceleration.
Old 08-06-2019, 05:04 PM   #501
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
Sure, I'll send you an email later this week. I want to see if I notice this the next few days.
camaroJD is offline   Reply With Quote
Old 08-06-2019, 07:27 PM   #502
L8Apex
Drives: 2016 2SS
Exactly the same experience for me as CamaroJD and Alltoeasy, I will give it another week, but will reach out to you if it doesn't improve.
L8Apex is offline   Reply With Quote
Old 08-06-2019, 09:16 PM   #503
Deputy Dog
Drives: 2017 Super Sport Cam.
Are you familiar with this issue? Or is this the first you have heard of it?
Deputy Dog is offline   Reply With Quote
Old 08-07-2019, 02:29 AM   #504
Z650HP
Z650HP's Avatar
Drives: 2019 Black ZL1 M6
Might be a SS thing. Have over 1000 miles on my TB and no surges. Just smoothness and instant response.
Z650HP is offline   Reply With Quote
